My sony str gx50es receiver has a flashing red P when I turn it on. No sound will come out and hitting any button does not change it. Is there a way to fix this?
My Sony str gx50es receiver has a flashing red P when I turn it on. It has previously worked and I have not changed any of the speaker wires or other inputs. It is stuck on an FM channel. I have hit all the buttons and nothing seems to change. When I unhooked the speakers the red P still appeared. Is there anything I can do?
5 Suggested Answers
SOURCE: Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Posted on May 28, 2007
SOURCE: No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Posted on Aug 17, 2007
SOURCE: "PROTECT"flashing, no response, STR-SE391
The audio amplifier IC are fried and need to be replaced
Posted on Feb 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Posted on May 21, 2010
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
Can't switch from tuner to photo on Sony str gx50es
behind the switches perhaps has bad connections on the front panel pcb
or the switches need taken out and apart and cleaned a tricky job
i do all the time in studios
so you need to take this unit as it quite old and a decent sony to a dealer or the local tv repair man
and have him solder it up and clean it etc
and replace any capacitors it needs changed out.. also
cost i think about £50 to restore fully
or diy = £0
Apr 13, 2015 | Sony Audio Players & Recorders
How do I connect my turntable to a str de-675 receiver
Take 2 rca wires a white one and a red one. On the back of the receiver, find a source you are not using( md/tape or aux ) connect red to red, white to white Turn on receiver and on the front, push related button( aux ). This should work. Good luck
Feb 10, 2015 | Sony STR-DE675 Receiver
I need to turn the volume knob to the MAXIMUM on my Sony STR-GX50ES receiver to get just a whisper of sound.
Possible that the preamp is faulty and so the power amp is not able to deliver the sound.
it will be good to check the input through to the power amplifier with a audio signal test, you can now confirm where the missing amplification is ,even start from power amp will be good enough.
Sep 28, 2010 | Audio Players & Recorders
I have a sony str-db940, since it came back from being repaired, it reports 'not in use' when the 'sur' button is pressed and won't decode surround sound. Any ideas?
Check if you're using the digital cables like optical cable to get the audio from the receiver. If yes, please select the Input mode to AUTO by pressing the mode button repeatedly. If you're using a analog cables, please try to change the sound field and check. Press the A.F.D button repeatedly to change the sound field and try. You can also try connecting a different audio source like Cable box, dvd player and check the issue.
If the issue persists, please reset the receiver. To reset the Receiver, turn OFF the unit and press n hold the MODE + button and Power button till S.F Initialize appears. If the issue still persists, you may be having 90 days warranty after the date of repair or original warranty which ever is longer. Contact sony to resolve the issue.
Sep 26, 2009 | Sony STR-DB940 Receiver
Sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Sep 22, 2009 | Sony STR-DB870 Receiver
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
Feb 06, 2009 | Audio Players & Recorders
No Sound.
Does tha ouput relay click about 6 seconds after power on? Is the speaker selector on A? Do you get sound using head phones? When on FM tuner is the stereo light on when set to a station?
I
Jan 24, 2009 | Sony STR-DE845 Receiver
Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
73 people viewed this question
 Grubhead
Grubhead
