Question about Funai Televison & Video
HDD error shut down - Funai Televison & Video
SOURCE: Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Posted on Apr 16, 2008
  • 99 Answers
SOURCE: hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Posted on Nov 24, 2008
SOURCE: HDD Error
Since my last post, I have rectified the problem.....
1) I opened the unit to find a seagate HDD
2) I downloaded the Seatools in dos format and burned the image on to a cd rom
3)Taking out the HDD from my recorder,I hooked it up to another pc and ran the seatools disk @ bootup.
I tried for 2 hrs to repair the bloody thing ( 160 gb!) so i gave up and tried to erase the full HDD...which worked.
4) on my laptop i navigated to Pioneers site and found my recorder along with instructions and a zip file that contained 2 files.
5)After reading the destructions erm i mean instructions ;) I put the HDD back into the recorder and followed the instructions again..
Crossing my fingers i turned the recorder back on and to my amazement i was able to have more functionality..BUT... it says my HDD name error so I ran the disk again and wallah! all worked XDDDD
Here are the links
http://www.pioneer.co.uk/uk/content/support/support/update/DVR.html check if your model is there.
http://download.seagate.com/seatools/registration.nsf/desktop?openform Just add your email too download.
I hope you fix yours XD
Posted on Dec 07, 2008
SOURCE: replace faulty HDD of Sony RDR-HX725(HDD ERROR).
I have the same problem, but no solution for me. Have you fix the problem? Could you use the remote successfully?
Thx
Posted on Jun 21, 2009
  • 945 Answers
SOURCE: LG DVB T HDD/DVD 197 won't play dvd's want error
http://www.scribd.com/doc/13204064/Lg-Dvbt-HddDvd-Recorder-Dbrh190197198199
Above is the manual for your dvd.
What we need to is eliminate first of all the discs that you can`t play etc finalised, region code.
Check through the manual.
Posted on Oct 20, 2009
No bootable device --insert boot disk and press any key
Sounds like your hdd has crashed. Look for a replacement hdd.
Feb 02, 2014 | Acer Aspire 5315-2326 Laptop Computers
0xc000007b error windows 7
Hard drive or data error. Try and run chkdsk/f
Generally just running chkdsk/f will fix this error. its normally down to bad sectors on a failing hdd corrupting data.
if your hdd shows more than 1% errors get it replaced as its failing. if its just the odd soft error then full formatting. may solve the problem if chkdsk/f doesn't.
Jan 29, 2014 | Computers & Internet
My dell inspiron 5620 wont go further a black error recovery screen
Shut down, unplug, remove battery, plug in, reboot, Try a system restore/recovery. If that fails, place a repair desk in the DVD/CD rom and reboot from DVD/CD rom, try a repair my computer first. Your MBR is missing or your HDD needs replacing. Is the HDD LED blinking at start of machine? Open the machine and reseat the HDD and memory mods. If that fails, remove HDD and test, replace if necessary. You didn't mention your OS? Windows XP? This may help: http://pcsupport.about.com/od/windowsxp/f/download-windows-xp.htm
Dec 17, 2012 | Dell Inspiron 1200 Notebook
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Hdd block error
Yes, better replace the hard drive. because even if you try and run a repair and work it will fail in the future. to keep your data safe i suggest that you replace your HDD now.
Oct 11, 2008 | Computers & Internet
HDD both IDE or SATA 1 are not recognized
Unplugg the disk from motherboard and reboot your computer
Shut off the computer, connect the drive again and start up again.
If the problem continue, set the drive on your bios manually.
If after that the problem continue replace the disk.
Oct 06, 2008 | Abit KV-80 Motherboard
Televison & Video Logo
15 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
