Question about Saeco Magic De Luxe Espresso Machine
Need main switch colours for connecton
A freind of my has remove the switch and now i dont know which wires to connect to the new switch . just need the colours as i have a brown blue , black , light blue.
thanks
    Brigadier General:
  • 3,614 Answers
May i know what is the exact model of the unit, and also the part# of the switch..
Thanks
Posted on May 17, 2009
I need a schematic for the controls on the handlebars for a 1976 harley fx shovelhead
easy , get a piece of paper and draw a plan view of bar switches and where all wires go to , write all colours of wires in place and find both ends of all wires cut and they will 99% follow suit in colours ! mite need to remove headlight lenz as most wires join in there and main loom comes out ( pending on make of bike , if fairing is fitted they sometimes fit to that in places ! let me know how you go mate ? good hunting P....
Dec 07, 2013 | Motorcycles
Hi I've just got a Honda cb250n and there now
Hi if you havent already checked the fuse at the starter solenoide 30amp check it first. Next locate the rectifier this will have 3yellow wires these come from the alternator and provide AC voltage to the rectifier which is then converted to DC voltage used for charging the battery, at the rectifier you have green wire/s this is the earth and red wire/s this is the voltage in and out, it is here at the connecting block you must inspect the condition of the wires do not unplug the block simply check for oxidiseing which is visible to the eye and is green in colour, simply twist and pull gently on each of the wires to check for conectivity, if any break off you can bypass the block by removing the wire from each end .next it is not uncommon on the old 250n for the ignition switch to become faulty, using a test light if you dont have one make one up by removing one of your indicators, the coloured wire orange or blue depending on which side you remove is the indicator live wire, at the ignition switch using your test lamp check for 12 volts by placing the coloured wire on the red ignition wire your lamp should light if you have voltage here, if you dont have power trace the wire back and look for breakages in the wire, you could also run a new wire from the battery to the switch and with this connected the switch should opperate normaly
Oct 20, 2011 | 1972 Honda CB 250
Hi! We have a really old williamson thermostat (not sure about the model but it says t87fi89i 2 8047 [dont know if it's i or 1 either]). We want to replace it with a honeywell t87n east-to-see thermostat....
On most applications for heating the red and white wires are used,however I would check what wires are connected to terminals on old thermostat. These connectons should be labled with initial of wire color,such as R,W,G,Y or Rc. If your green wire is hooked to R or whatever just hook new thermostat up like the old one and you should be ok. Hope this helps. Thanks.
Nov 12, 2010 | Honeywell Electronic Programmable...
How i wire a GSX-R 600 year 2003 ignition
there is a resistor inside the ignition on the black box you need, twist the RED and ORANGE wires, the orange wires are actually one wire split into two further down by the connector so cut the red and orange wires from here. you then need to join the ORANGE/YELLOW wire to one end of the resistor and the BLACK/WHITE wire to other end, clean up and protect with electrical tape and snip other two wires, you dont need them. now can you tell me what colour wires connect to each other on the right handle switch, i need to know the colours of the wires on the switch side where it connects to the main wiring harness (both sides plz say which is which!!) cheers mate
Nov 13, 2009 | 2003 Suzuki GSX-R 600
I have a 2007 sony car stereo model#CDX-GT710 and I dont know what wires are for what please help?
HAVE A LOOK AT YOUR MAIN LUG WIRE WHILE YOU ARE READING THIS:
YELLOW-----MAIN WIRE 12V+FOR FULL TIME
RED-----IGNITION MAIN WIRE 12V+ SHOULD COME ON WHILE YOUR CAR IGNITION IS ON, SHOULD BE CONNECTED TO IGNITION SWITCH
BLACK--------GROUNDING12V-
GRAY-GRAY-------SPEAKER-1
WHITE-WHITE.....SPEAKER-2
GREEN-GREEN------SPEAKER-3
PURPLE-PURLE----SPEAKER-4
please be noted, that wire colours are differant as mentioned, and if they are in pair, they can be regarded as speaker wire.
BLUE---POWER REMOTE
BLUE WITH WHITE STRIP-----AUTO ANTENA POWER
Oct 15, 2009 | Car Audio & Video
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
I have a 1980 alfa spider that i dont drive it been sitting for about a year. i had notice i had taken the coil out of the car. I purchased a new coil at autozone and put it on looking at a setup from my...
you need to source either the repair manual for them
or just the ignition wiring diagram and wire colour legend for the 1980 and 1985 alfa spider
to see if wire colours are different
search online
at the minimum
there should be two power wires in with start and accessories an earth
not sure if a starter relay was used in the 85
Mar 31, 2017 | 1982 Alfa Romeo Spider
Need connecton diagram for ASUS P4S-LA motherboard.
if colours don,t match up. your main connectors hdd/pwr/reset remove the front panel on the computer. and check from the switches located on the front panel. or you could use a multimeter and test for continuity. if you have one.
you should have green/white red/white orange/white Or blue white.
Mike @ Compurepair.
Mar 15, 2009 | ASUS P4S800-MX Motherboard
Please help..very important..dont know wat to do
place the monitor away from the wall by 10Cm. and no telephones or modems or wireless near.
May 04, 2008 | Computers & Internet
Saeco Magic De Luxe Espresso Machine Logo
49 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
