Question about Gateway FPD1530 15" Flat Panel LCD Monitor
Blinking green light with no display
I have had My FPD 1530 monitor for about 2 years, just recently when I turn on the computer the monitor display will not work.  I know that there is power to the monitor because of the green flashing light.  I have checked and rechecked all the connections they are fine.  I changed to a different monitor and it works fine.  I then changed the cables, still with no luck.  Any suggestions?
  • 2 more comments
  • sexirabbit Nov 03, 2007
    I pluged it up to my computer and all it shows is a lime green screen but others work fine how can i fix this
  • Anonymous Dec 14, 2007
    i turn off the computer & the monitor blue light keeps blinking
  • cougarvol Jan 19, 2008
    How does one reset the BIOS?
  • Anonymous Jul 04, 2008
    I have had My FPD 1530 monitor for about 5 minute, just when I turn on the computer the monitor display will not work. I know that there is power to the monitor because of there is video but no brinee enough.
Sometimes u might think that the monitor have problem... but its not... its the vcard... try this 1, hope it works... open the casing of your cpu.."dnt be afraid ro open it as long as its unplug"... now get the card.. use a pencil eraser to clean the coper line on it.. then put it back to the cpu... turn on your computer.. and it will work... u can also do it if your computer keeps on rebooting.. u also need to clean your computer every month. sometimes the card was not recognized or read bcoz it has a mole.... hope my simple tricks work for u guys...
Posted on Feb 01, 2011
Had same problem and read the posts about discarding the monitor and get a new one. then I realized that may be the dvi connection on the monitor may be malfunctioning. Lucky me the monitor had the option for vga connection. So I connected the computer to the vga port of the monitor through an adaptor (dvi-vga) and voila. The monitor is back on again.
Posted on Mar 14, 2010
  • 51 Answers
Have you tried connecting this monitor to another computer?
Have you tried resetting the BIOS? That should reset any problem the video driver for the monitor maybe facing.
Posted on Oct 17, 2007
Monitor comes on and then turns off
You can have shorted out transistors, transformers, bad lamp assembly (this one will be hard to test if you do not have the tester).
Please send me pictures of the board so I may be able to point out where to test. budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 09, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD 1730 Monitor
What has happened is part of your back lighting circuitry has gone out. Yes it is repairable but can cost most of what a replacement monitor will cost these days. Check that out before spending the money. If the problem is only in the back lighting circuit then expect to spend about $100 for a replacement board.
LCD monitors lifespan depends on the quality. Normal use and you should get 2-3 years of reliable service minimum. The display itself is good for about 4000 or so hours of use or more. The problems that show up are always (well 99.99% of the time) are back lighting problems like you have experienced. You should turn it off by the switch when not using it as every hour it runs the screen save is an hour of usable life. Heat is not good for it so if your computer gets the dust cleaned out to keep it cool do the monitor at the same time. Once a year at least more if you smoke use gas heat and have pets.
Tube monitors have a much longer life but you have the size weight and poorer display to go with them. If you have to go back to a tube monitor don't go back to your 14 ask around and you should be able to get a 17 or 19 crt for free. Or expect to pay no more than $10-20 for one.
Jul 10, 2009 | Gateway FPD1775W Monitor
Can't go higher than 640x480 resolution
Go to device manager-> expand display adapters. Rightclick on the video adaptor and select properties. Click on driver tab and select option RollBAck driver.
May 27, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
When power light is green I have no display on the screen
dwanlesso6, Please tell me brand of monitor and if it is LCD/FPD and size 15,17 19 etc. If it is an LCD then it is possible that the DC power supply and or inverter board has failed. Here is short PS101 lesson. All electronic things (Stereo, printer, radio, computer, TV,) all require DC voltage. You get AC Voltage from outlet on wall. the two don't mix. ever!! All the above mentioned things have AC to DC power conversion circuits. They are called power supplys. Only your's and everybody's LCD monitor has two. One makes DC for the monitor logic/digital kinds of stuff, 5.0volts and also makes a
second and higher voltage ( 12v or 15v or 24v) to send to the other power supply which is called an inverter power supply. The inverter PS changes DC into a higher frequency Square Wave AC voltage to power up the Fluorescent Tubes that make your display "bright white" !! Do you own any of those new style light bulbs. You know... the ones that look like small coiled fluorescent tubes and screw into the same socket that previously held the old filiament type of light bulb. Well your dealing with the same technology in your monitor. Just for kicks, you can go to www lcd-monitor-repair. com. Don't pay any attention to the 'advertisement' !!!! just look at the pics of what is inside an LCD/FPD.
The advert just wants you to buy books on LCD/FPD repair.. The best advice I can tell you is try to locate some repair shop that specializes in FPD troubleshooting&repair. Hell, I too am waiting for this 19in GatewayFPD to die. Hope is later.. not sooner, or I'll be in same boat w/LCD/FPD for anchor. Good luck. I'm lmistyrel @ aol north of Chicago been in electronics >3decades
Jan 12, 2009 | Westinghouse L2046NV Monitor
Gateway FPD 1830 LCD Monitor
User "noclew1"
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
As for User Guest
Your issue is nearly the same issue when it turns off on you. But the doubling effect is from the power being supplied by an old or weary power outlet to an FPD. That can be the cause. Try different locations.
Well I wish you both luck and I hope this solution can help you with the problem.
Thanks
Victorsinferno45
Aug 30, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
832 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
