Question about Technics SL-PD8 5-Disc CD Changer
Had to open up the unit to get a stuck cd. Which ribbon cord plugs in where?
Is there any adapter to use the 9 pin flat ribbon system control cord on other systems.
You posted in the category 'Laptops'. You want to power a CD Player unit out of a computer to run from mains power?
The flat ribbon cable is the data cable, so no.
Power is by a separate lead which supplies 5 volts or 12 volts via the Power Supply Unit.
Jan 05, 2016 | Computers & Internet
When I plug in power cord, unit says "Hello", cycles through all settings, says"goodbye, then starts all over again. I can play a CD all the way through.
Sounds like its stuck in demo mode. Look up model number on the internet if you don't have a manual. Hope this helps
Aug 11, 2013 | Audio Players & Recorders
Need to know how can I open the 123 Bose system when the cheap CD is stuck inside it says it's open but it's not thank you
    • Turn off the device.
    • Disconnect the Acoustimass module power cord from the electrical source. Wait 60 seconds. Plug the cord back into to its power supply.
    • Hold down the "Eject" button.
Feb 01, 2013 | Televison & Video
Hi my problem is with the dvd tray it does not open . it make a funny noise but it does not open thx
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Jan 31, 2011 | Panasonic SC-PT660 Theater System
Ribbon cable broken and now cannot open the face plate
You need to take the unit apart to fix the cable since the other end of it plugs into the board inside, it's pretty easy to take apart though. Good luck!
Feb 09, 2009 | Pioneer DEH-P8600MP CD Player
Cannot eject or turn off power on my pioneer deh-p8600mp
when you take the unit out of your car and looking at the top of the unit there are two black screws. Remove those then remove the entire cd player cage by the 4 CHROME screws on the four corners of the cage the two in the front are in the two holes in the ver front (**use magnetic screw driver for this**) then disconect the two wire plug and the ribbon cable from the bottom of the cd player cage **BE GENTLE** there are two black tabs on either side of the ribbon cable. THEY ONLY MOVE ABOUT 1/8TH ON AN INCH using a jewler flat blade screw driver gently slide the clip out to un crimp the ribbon cable then once the cage is removed you can open the face. To open the face there is a white gear wheel on the rightn hand side of the unit you can rotate it with your thumb with a little effort. Rotate accordingly..... at that point you shouldnt have any problem but let my know if you do..
Dec 10, 2008 | Pioneer DEH-P8600MP CD Player
Door stuck open
disconnect all plugs .
remember all plugs where are all there were.
than clean your plyg ,& sockects also,
re-connect all plugs & sockets.
do this with care,it takes time.
THNX
May 15, 2008 | Computers & Internet
Disc is stuck in machine
When the try is stuck:
On a Lifestyle system with a tray that won't open, try this:
  1. Turn off the power.
  2. Unplug the power cord.
  3. Wait at least 5 minutes.
  4. Plug the power cord back in.
  5. DO NOT TURN THE UNIT ON !
  6. Hit the Open/Close button.
This worked perfectly for me!
drgeri
Dec 24, 2007 | Bose Lifestyle 38 System
Multi cd bose player will not eject 4th cd.
OK, this problem is everywhere with the bose cd changer addon. Many people can still play a cd with the top one fine, but cannot get cds to eject and/or read in 3 disc changer. My friends mom had one and after finally hearing back from bose, they said send it in with $100 to get fixed. If you have to send in and you value your cds, you may want to open it up and get them out. Use this at your own risk, there are no warranty stickers I saw and there will be exposed voltage, shock hazards, etc.; so if any of this worries you, stop here. By proceeding, you are admitting that you are capable of minor repairs and therefore I'm not responsible for any damage or harm caused. OK, here it is:
Unplug everything. On the bottom of the cd changer unit are 4 screws (silver ones recessed about 3/4" or so, use phillips screwdriver) to remove. Turn unit upright again and lift cover slowly straight up. In the front of the unit is a ribbon cable you will want to disconnect that goes to the cd 2-4 lights. Take note which side the dark blue tab is on and gently pull out by dark blue tab, rocking side to side if needed) You can then pull cover all the way off and set aside. Plug power into back of cd changer (careful not to touch anything inside) and see if the cds want to eject now. If not let the initializing process finish and repeat. This time see if you can gently help the cd out. The problem may also be the spindle not lowering, you can look for this movement during the last step of init. process. Work your way fom the top tray down removing the cds gently, remember we open it up because they were valuable to us, don't destroy them now, and don't ever use anything that could possibly scratch either top or bottom of the cd, use edges instead. Start to replace cover making sure to reattach ribbon cable back into socket the same way it came out. do not force too hard or you may crease and break ribbon. Gently replace cover and grab both top and bottom to turn over. Replace 4 phillips screws making sure not to overtighten or cross-thread. Now you may return to bose or just find an independent repair shop in your area, they are usually quicker, more polite, usually cheaper, and best of all, local!
Dec 15, 2007 | Bose Wave music system Multi-CD Changer...
Screen will not open
I have the same problem and found it is the ribbon cable to the faceplate holder. As the plate folds down it breaks the connection in the bad part of the cable and the deck doent see the faceplate, thinks it's been removed and begins to close. As it is closing the ribbon cable straightens and makes connection again. Hope this helps. Kkarma
Dec 12, 2006 | Pioneer Premier DEH-P960MP CD Player
Technics SL-PD8 5-Disc CD Changer Logo
22 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
