AC not stops working when compressor starts.
Godrej window AC 1.5 ton,
Model NoL GWC 18G5 WHM
I purchased a AC 2 weeks ago, intial 1 week i dont have any problem in cooling with single booster 4 KVA, but after 2 weeks, i used to encouter problem like when my compressor starts the AC gets off and again restarting after 3 mins but it keeps on when it works on FAN mode but when i change the mode to cool, its getting off when compressor on(Clicking sounds), after getting advise from my friend he suggested me to go for double booster, so o purchased V gaurd 5 KVA double booster, but still when my voltage drops the ac gets off, can you please justify whether the problem is with AC or Voltage, if i use double booster then i shoul work right ??, but the same is not working. please suggest a solution.
Thanks
Amrish
  • Anonymous May 21, 2009
    its 180 V, and voltage flactuation problem also occurs but after non peak the voltage is stable.
  • Robert Moller
    Robert Moller May 11, 2010
    Why do you need a booster to begin with ? What is the supplied voltage. A little more detail please.
  • 148 Answers
How many amp service do you have in the house
Posted on May 17, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Error code E9? in godrej split 1.5 ton AC
Godrej 2 ten indoor despily e9 cood
Mar 17, 2014 | Heating & Cooling
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
My 1995 gmc 1500 ext cab siarra 's ac stopped cooling, i put at least 2 1/5 cans in it about three weeks ago, it was running fine until a day ago, please tell me what is wrong, is it compreesor re
You have a leak,to see if you do,get a spray bottle,put soap water in it and spray all a.c.lines and see if it bubbles up any where.Look for usual stains at connections.
May 25, 2013 | 1995 GMC Sierra C1500
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Can the compressor run w/ a 'blown' capacitor?
The capacitor starts the motor. You would have had some other problem had the motor not started. The A/C ran until the failing capacitor no longer provided the ability to start the motor at which point your A/C died.
My A/C bulged both its capacitors 2+yrs ago and it's been running ever since they were replaced, no problem.
I think you're OK.
Sep 13, 2017 | Carrier 38CKC060 Air Conditioner
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
LG Window AC Problem
send it back again!
May 03, 2009 | LG Heating & Cooling
2000 tracker ac trouble
check the fuse. I had the same problem 2 summers ago. I checked the fuse myself, and fixed the problem for about $2.00!
Jul 27, 2008 | 2000 Chevrolet Tracker
Heating & Cooling Logo
764 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
