Question about Toshiba DVR670 Player
Vhs tape won't go into machine correctly
The mechanism only drops on right side and not on left
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Posted on Oct 15, 2012
Magnavox vhs and dvd player vhs insertion issues
Someone is going to have to take the unit apart---mechanism issue with the tray or the gears that lower it etc---not too many shops left that work on VHS decks anymore so call around first.
Dec 03, 2012 | Televison & Video
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
Oct 14, 2012 | Toshiba M754 VCR
PLAYER SWITCHES OFF WHEN PLAYIING VHS TAPES
check any mechanical failure in the vcr unit. like tape won't work properly might some obstruction or plastic broken.
Sep 15, 2012 | Toshiba DVR660 DVD Recorder/VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
I have a ION VCR2PC and the power button won't stop blinking. Also when I put a VHS tape in, it turns itself on and then right off again and ejects my tape. There is not anything stuck in the ION...
If the take up spool is not turning properly it is not uncommon for the machine to eject the tape and turn off. Check the drive to that spool and correct.
Sep 08, 2017 | ION Audio VCR2PC VHS VCR
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Vhs tape won't load completely
I assume the cassette flap lifts fully, allowing the tape to go into the deck as this is a small lever mechanism. When the tape goes so far in, it activates a switch to start the loading motor this is usually a metal or plastic pin on the deck depending on the make of VCR (as you do not mention the model of your VCR, I can only give you an overall explination of a carriage mechanism). The pins at the side can incorporate a start sequence as well & will guide the deck into position. It looks like your machine has gone out of alignment & to solve the problem you would need to remove the cassette housing & re-align the pin at the side so that it follows the correct path, this can sometimes be a tricky & awkward thing to do as you can break parts of the deck if it is not aligned correctly. My advice would be to take it to a service repair centre.
Jul 21, 2009 | Televison & Video
Stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 07, 2008 | Optical Coating Model 108 VHS VCR
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Toshiba DVR670 Player Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
