Question about Refrigerators
Beko gnev221apb red error light
Red exclamation light on display and a big build up of ice
SOURCE: 1992 Toyota Previa - dashboard icon on - red exclamation light
I had this, red ! came on briefly around bends and after short stop at lights etc. It was low brake fluid so as it would slosh to one side it would drop below level and display warning. Check and top up asap.
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Posted on Jan 31, 2010
  • 523 Answers
SOURCE: The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Posted on May 05, 2010
SOURCE: BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Posted on May 10, 2010
tiger56h
  • 176 Answers
SOURCE: how do i prevent ice build up in the refridgerator
check the timer
Posted on Aug 23, 2010
My fridge freezer red exclamation warning light has appeared on the temperature panel it has never happened before help ! What does this mean I have a Beko AB 910S
The red exclamation mark means that the freezer is too warm to keep items frozen. Make sure that the freezer door is closed. If the freezer is opened frequently, reduce the number of times that the door is opened. If you put in a lot of fresh food, you may have to wait for the freezer to chill.
If the problem persists, then you need to check if the fan is running properly. Replace it if needed. Otherwise, the freezer sensor may be faulty.
The manual for the AB910 is available online. One source is at Manuals Lib: https://www.manualslib.com/manual/15132/Beko-Ab910.html . Beko has some of the parts here: https://www.bekospares.co.uk/fridge-freezer/ab910s-7218846385/catalogue.pl?path=110911&model_ref=11336069 . Other sources will probably also have the parts.
I hope this helps.
Apr 26, 2018 | Beko Refrigerators
Beko fridge freezer I have square red sympol with an exclamation mark flashing
consult manual for trouble shooting or contact support through manufacturer website
Jul 23, 2016 | Beko Refrigerators
Frigidaire elite, red alarm light on,freezer defrosted, fridge icing up
Sounds like your heater is either out or the connectors are loose causing it not to be able to cool properly from ice build up
May 08, 2014 | Frigidaire Refrigerators
Red light problem
If you are getting the red light error this is caused by different things depending on how many red lights you having showing up:
1 red light is the display chip overheating
2 red lights is the whole console overheating and you should try and cool it down to fix this.
3 red lights is the most common error and it is caused by the GPU and the CPU overheating, you will need to stop the heat build up.
4 red lights is just the AV cable not plugged in normally.
To fix the 1, 2 , 3 red light error you will need to send it in and they will fix it for you.
The only problem is that this can take about 4 weeks and you will also have to pay out a repair fee to fix the problem.
The other way is to use a good Xbox 360 Repair guide that will show you how to stop the heat build up on the chips.
There are a few of them about but i have put together a list of the top sites HERE.
I hope this helps and if so please rate it so it can help others.
Jan 07, 2011 | Microsoft Xbox 360 Console
E73 error and one red ring in the lower right quadrent. AV power cord when unhooked- no red light- when reattached red light reappears.
1 red light is the display chip overheating and to fix it you need to stop the heat build up getting to the main chip to do this you need to send it in or use a good xbox 360 repair guide to fix it
Nov 17, 2009 | Microsoft Xbox 360 Console
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Open Questions:
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
