Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
DYT 4000 Lawn tractor won't start
The lawn tractor turns over, but won't start. Getting Spark and appears to be getting fuel. Just seems to backfire through the carb. Had it all apart, cleaned everything but still won't start. Pulled fly wheel and checked and cleaned out coil area. Checked shear pin, everything looks ok. Not sure what else to do. Any suggestions.
  • tomicamel May 25, 2009
    I have the same situation. 17.5 HP model. Has spark, gets fuel, perhaps too much, and sometimes almost starts. Blows some smoke and cuts out. Ran fine a few days ago. Have replaced plugs, cleaned air cleaner.
    Problem Solver:
  • 10 Answers
Does it have a manual fuel shut off or a electric selenoid type
Posted on Aug 06, 2009
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
Posted on Aug 11, 2009
Tractor will not start.
Are you getting spark to the plug(s). Check with spark tester. Is fuel getting into the cylinder(s)? When it turns over, do you get a spit or backfire? If yes, check flywheel for key.
Dec 05, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LTS 1500 lawn mower - model # 917.28903 started sounding funny while i was cutting VERY high grass. I turned it off immediately and it backfired as it shut off. Wouldn't restart. Waited til next...
I would check the big three first of all. Spark, compression and fuel. Sounds like you have spark and fuel. I would get a compression tester to check actual amount of compression. If all three of those things are good I would check valve lash. You will need make, model and serial number of engine. If you post these I can help find specs for you. Good luck.
Sep 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower won't start, looking for help to troubleshoot.
take your lawn mower to whom you bought it from and ask them for help
May 22, 2012 | Husqvarna Garden
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you remove an engine from a Craftsman dyt 4000 lawn tractor?
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Jun 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Lawn Tractor won't start after wrong fuel used, drained, etc
Check the fuel shutoff solenoid (on the bottom of the carburetor -- has a wrie plugged onto it) -- it may be sticking.
Spray carburetor with carb cleaner. Then if you can get it to run long enough to do any good, put carb cleaner in the fuel -- follow mixing proportions on the label.
If this doesn't work, need to take carb apart and thoroughly clean it.
Charlie
Aug 29, 2009 | Garden
Will crank but won't fire
To run, the engine needs fuel/air mix, compression, and a spark. See if you can narrow your problem down to one of these. Remove the plug, then connect the plug wire and set (or carefully hold) the base of the plug against the cylinder head. Crank the engine and see if there is a spark. If not, the problem is in the ignition system.
If you see a spark, replace the spark plug. Remove the air filter and pour about a tablespoon of gasoline down the carburetor throat. Crank the engine, being careful to stay away from the carburetor in case it backfires. If the engine fires and runs, then it probably is not getting gas (fuel system problem), or not getting enough gas (carburetor or choke problem).
Compression problems are less common, unless the engine has been abused somehow. You can check for compression with a compression gage. Remove the spark plug, install the compression gage in the spark plug hole, then crank the engine with the throttle open and the choke off. If you get at least 60 or 70 psi when you do this test, the compression is probably not the problem.
Apr 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
881 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
