Question about Refrigerators
Ge gsh25jsta ss
Crushed ice only in door no cubes
MNTECH
  • 1543 Answers
SOURCE: PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Posted on Nov 20, 2008
peyton32034
  • 410 Answers
SOURCE: icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Posted on Jan 22, 2009
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
  • 3 Answers
SOURCE: ice dispensor only dispensing crushed ice - not cubed
The spring coming off the rod will also cause this problem, also the bypass flap may be stuck open, always check the simple things first, hope this helps.
Posted on Apr 16, 2009
I have a GE GSS25TSRD SS refrigerator. The cubed ice dispenses properly but crushed ice is not working. Any thoughts?
Remove the ice bin and move the metal bar that sticks out the back of it up and down. It should move easily and spring back. If ok look at the white plastic square piece below auger where the metal bar inserts into when bin is in place. You should be able to lift that up and down easily. If its stuck it probably needs replacing. If thats ok then press the freezer door switch in while pressing the dispenser paddle for cube ice. The white plastic part should move up the down when paddle is released. If no movement the solenoid is bad for it or its not getting voltage.
Sep 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice door not working
I have the GE Profile BSS25JSRF SS and have had similar problems: fixed the water dispenser by putting a hair dryer on it for 2-3 minutes. Sometimes this will freeze up and needs to be thawed. However, I still get no ice through the door. Hope this helps.
Apr 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge pss26sgrc ss ice/water dispenser
Take the outer frame off the dispenser area with a plastic putty knife. Start at the bottom and gently pry off, trying not to snap off plastic tabs that extend into door. Most likely you will have to replace the "interface" (part # WR55X10415) It is the small board where you select water / crushed ice / cubed ice. Relatively easy to replace. good luck.
If this helps, please rate response. Thanks.
Aug 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
there is a door in the bin that switches the cubes empty the bucket and make sure its not jammed also take the bucket out push cubes hold down the door switch not the one that turns the light off unless you unit only has one and push the switch with the door open in the back a leaver in a hole should jump up it not switch it to crushed and try it again if it still don't then the solenoid is bad or frozen
Feb 18, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
