Question about Comfort Zone 5,120-BTU Multi-Purpose Ceramic Heater, Black CZ442WM
I have a comfort zone heater model: cz442wm the fan stopped working
hotuna
  • 288 Answers
SOURCE: Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Posted on Nov 13, 2007
  • 7 Answers
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Posted on Oct 02, 2010
  • 13 Answers
SOURCE: my comfort zone heater wire element is glowing and
dust and dirty air can be one problem or some object has fallen in to it you may need to get it cleaned
Posted on Nov 29, 2010
  • 383 Answers
SOURCE: Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
Posted on Jan 15, 2011
  • 4736 Answers
SOURCE: I bought a Comfort Zone
If it's under warranty, the "hassle of shipping it off is small", compared to possibly doing more damage, while trying to repair it yourself and voiding the warranty. Once they repair it, the warranty starts over again. Just make sure you get authorization from Comfort Zone, before shipping it to them..
Posted on Mar 22, 2011
Fan not working on our cz20110 comfort zone heater. Ca we fix orselves and where do we get the part?
If you have the fan out you can look at the part number and do an internet search for it. You will have several options come up for a replacement. There are several manufactures or the same part.
Mar 25, 2016 | Comfort Zone Heating & Cooling
How do I reset my Comfort Zone heater?
The top light is coming on but the fan isn't working
Feb 20, 2015 | Comfort Zone Heating & Cooling
Electric utility heaters
Make sure the thermostat is switching...check the power going through
Dec 17, 2013 | Comfort Zone Heating & Cooling
I have model NO cz798 , it keeps runing this morning it was 82 O" F
my space heater power light come on but the fan has stop moving.i
brought this heater less than 30 days ago
Nov 12, 2012 | Comfort Zone CZ792 Electric Utility Heater
My comfort zone cz792 utility heater will come on and fan will blow and it will stop thn start then stop and was not doing this a week ago when i first bought it. what is causing this?
With the heater unplug from power source, check for continuity between the two terminals on the thermostat. If you get an indication on your multi-meter of infinity, then the contacts of the thermostat are working correctly. No indication of continuity, is probably because the contacts ofthe thermostat have burned out and have decrease in thickness, breaking the circuit. I know of no place in which you can find a replacement thermostat. The contacts on the particular heater where evidently designed of inferior material. I have had two and had the same problems with both. You get what you paid for.
Nov 18, 2011 | Comfort Zone CZ792 Electric Utility Heater
My comfort zone heater is cz499r with remote, I posted a comment earlier about my heater smoking and not turning on, my return date ended jan. 15 is there anything i can do? I got the heater from big lots!
What you have is a very dangerous situation. It may not be a newness smell. It may be the plastic melting. Many of the Comfort Zone heaters were recalled in December 2010. Search Google for Comfort Zone Heater Recall to see if your specific model was included
Big Lots has some great pricing and deals, but some of their electric appliances are Factory Refurbished Units. If that is the case, it is required that the box it came in must indicate that.
Jan 27, 2011 | Heating & Cooling
My comfort zone 1500wo isn't cycling on and off. Do you know what is happening & how to fix it?
Hi, I just got my comfort zone 1500w and same thing. I called Comfort Zone this morning at 1-800-221-6895, they are most pleasant and helpful. She said it was because I had it on the energy saving mode. When it is set to that the fan runs continuously and never shuts off. She said to put it to the low or high setting and once the temp is reached, it will automatically shut off. Then when the temp drops it will turn on. Cycling off and on doesn't work with the energy saving function - she couldn't really give me an explanation for it just said don't use it if I want it to cycle off and on. Hope this helps.
Dec 22, 2010 | Comfort Zone NEW 09 Electric Portable...
Need manual for serial # E0825340 model CZ 1500 wt
my comfort zone cz1500wt shuts off when turned on code A03 appears on the display
Oct 25, 2010 | Comfort Zone NEW 09 Electric Portable...
My comfort zone is not heating I had a infarared bulb that went out replace the bulb the heater still want come on it is hard to get techical support to tell what's wrong.
The bulbs on the older (pre-fall of 2010) Comfort zone heaters are in pairs... if one bulb of the pair is burnt out the other will not work. Also they are not easy to line up when replacing them back into the recepticle...they must line up perfectly to work.
Oct 05, 2010 | Comfort Zone NEW 09 Electric Portable...
Comfort Zone 5,120-BTU Multi-Purpose Ceramic Heater, Black CZ442WM Logo
485 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
