Question about Water Heaters
Alvima portable gas heater instructions - Water Heaters
Triton 10 L wont light up has inginiton but not getting gas
There is something that must be blocking the pipe for the gas to flow check the pipe
Feb 12, 2014 | Camp Chef Triton 10L Portable Water Heater
How do i light the pilot light
Usually 1 minute.
Copy following link to identify gas control valve and read lighting instructions:
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene
h
Dec 12, 2013 | Bradford White MI40T6FBN 40 gallon natural...
Hi... im at a friends home and am in need of help with the water but cant find an operations manual. The top pilot switch was set to off and the bottom temp control was on vacation. Am i able to just...
Identify gas control valve, with instructions for lighting each type... these instructions also show on side of water heater.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Knob rotated to off...means pilot light is off, and water heater is off.
Read instructions shown with each gas control valve shown on link above.
Don't forget that gas supply to water heater has to be ON. Gas shut off valve must be parallel with gas line.
http://waterheatertimer.org/images/Gas-water-heater-89a-350.jpg
Gene
h
Sep 19, 2013 | Water Heaters
How do I light the pilot
1) Open following link to identify type of gas control and read printed 'how-to-light-water-heater' instructions for each different gas control valve:
2) Same printed instructions should appear on side of tank by gas control valve, and inside product manual.
3) Add a comment March 2013 and describe gas control valve.
Mar 13, 2013 | Reliance & 40 Gal Mobile Home Water Heater...
Gas valve replacement procedures
Tank-type gas water heater control thermostat?
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Tankless gas water heater.
Each brand and model might have different instructions.
Some tankless companies post manuals, most do not, and want work done by professional.
Nov 06, 2012 | Water Heaters
We have a plumbing technician to repaire the water leakage out side of our house, which need to turn off the water supply to our house. After that, we found that hotwater will not turn on (burner light...
You have gas water heater.
Probably a tank-type gas water heater.
The plumber can fix water heater.
If you want to fix water heater yourself, then more information is needed to narrow down scope of answer.
1) Add a comment for possible help.
Instructions for lighting the water heater appear on front of water heater. Do those instructions include lighting the pilot light?
Will the pilot light stay lit?
On side of tank is a label. Label shows Brand, type (LP or NG), and model number.
This information can help narrow the type of gas control valve, and point direction for troubleshoot.
Add a comment with this information for possible help.
2) Do-it-yourself: Open following link for do-it-yourself resources to help solve gas water heater problems:
Generally the instructions show how to clean water heater parts, check venting, and show different types of gas controls, plus links for pilot light problems and cleaning air intake.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 24, 2011 | Noritz Water Heaters
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
Lighting instructions
More information is needed.
You posted under electric water heater.
Are you trying to light a gas water heater?
Each water heater is different depending on gas control valve.
Instructions for each gas water heater are printed on front of water heater at gas valve.
Add a comment and describe the gas valve, describe what the instructions say, and describe what general problem you are having for possible asistance.
Jul 06, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Just purchast and installed everything hooked up push the sparker looking through window I see nothing
You posted under Reliance gas water heater
You installed a new gas water heater and are trying to light water heater using the piezo igniter.
Not clear is what steps you have taken so far, and which gas control valve is on the new water heater, and what lighting instructions say on side of water heater.
Also unknown if you bled air out of gas line, or if gas shut-off handle is rotated so handle is parallel with gas line.
Read instructions written on side of tank, open link below to double-check installation, and then add a comment with steps you have taken so far, and describe the type of gas control valve on water heater.
Jul 03, 2011 | Reliance Natural Gas Water Heater Control
Replace Reliance Water Heater Gas Control Valve
there are no instructions for doing this.
how do you know it needs replacing? its rare that they need to be replaced.
I can help you, but need to know what is going on with the unit first
Apr 17, 2010 | Reliance & LP Gas Water Heater Control
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
