Question about Watches
Skagen usp 5870803
Is it possible to by only a new bracelet
3 Suggested Answers
  • 103 Answers
SOURCE: Size watch bracelet
your band is Skagen Signature Mesh
http://www.skagen.com/service/watchInstructions.fx#adjustment
Posted on Aug 04, 2010
SOURCE: Rubber bracelet broken
Contact Skagen on line and provide the model number of the watch that should be found on the case back. They should be able to provide a replacement.
Posted on Nov 06, 2008
Skagen watch - 233 SGS - the clasp on the stainless steel bracelet is not secure - the clasp comes undone in normal use - nothing energetic - and the watch falls off - been lucky so far as have either...
Hi ,
i would contact Fossil group as they are the manuafcturer of Skagen watches . looking at the model it uses a slider type clasp.
the metal on the locaking part can be easily bent causing to come undone.
Aug 25, 2017 | Skagen Watches
My gunmetal titanium band (only half of the band is broken, what do I need to get it repaired or replaced???
some watches provides bracelet parts to replace, like rado, tissot etc...otherwise you have to replace whole bracelet, as per my experience titanium cant be solder nor repair
Feb 23, 2010 | Skagen Signature Mesh watch
When I flexed my wrist backwards, the crystal on my titanium Skagen cracked!
This sounds rather unusual, as flexing the wrist can pull the pins out of the lugs but should not damage the crystal.
If it is still under warranty, then take it to a local dealer for watch.
I suspect that you have a rigid strap and this puts a strain on the watch. I gave up using leather straps 30 years ago because of continual troubles like yours (a flexible bracelet will prevent this) and have never had any similar problems ever since .
If you have to pay for a new crystal, then investing in an expanding braceletshould be considered.
Jan 25, 2010 | Skagen 170LTTM Wrist Watch
Skagen watch/ How do you adj the links?
its a pretty easy link to remove on the lower part of your band there are pins those pins have a large side and a small side. you can use a tack to apply pressure to the small side. make sure the pin has somewhere to go( you dont want to bend it) press the pin out the other side.
remember your watch only has about 4 links that can come out.
Dec 27, 2009 | Skagen Titanium Link Bracelet Band Watch...
How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Jan 10, 2009 | Skagen 355LGSC Wrist Watch
Size watch bracelet
Dec 26, 2008 | Skagen Watch
Lost screw to secure watch band on Skagen 355LGSC
You just have to to see the watchmaker. As all watch band screws are made to particular bracelet, it's allmost impossible to find the right one if you are not in watch repair business. It will not cost too much and will save your time and nerves if you'll ask the watchmaker.
Find your nearest watchmaker and ask for help.
Dec 22, 2008 | Skagen 355LGSC Wrist Watch
Nov 04, 2008 | Skagen Watches
Shorten band
Hi Go to www.skagen.com top r/h search box - input your model number click on go,
On the new page at bottom/left, click on customer service.
On new page left side click on instructions.
On new page you will find instuctions on how to shorten/lengthen bracelet.
Oct 24, 2008 | Skagen 107SSSBD Wrist Watch
How to adjust a Skagen Denmark Women's Steel Watch so it can fit my grandma?
good morning ! look the smooth side of pin on side part of your watch bracelet, just push it use pointed puncher pin and anvil to do that ,good luck !..
Sep 05, 2008 | Skagen Watches
Watches Logo
612 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
