Question about Ricoh 6513 Copier
Aficio color 6513 id sensor location, td sensor location
We are getting an sc385 error from our aficio color 6513 and from what i have discovered, the id sensor and the td sensor may need to be cleaned. where is the id sensor located? is the td sensor the one located in the centre of the toner revolver? if it is, i have cleaned it but there is no change. if this is not the td sensor, where do i find it? i have cleaned all visible connections.
any help greatly appreciated.
  • 58 Answers
Toner density sensor is located in the developer unit. either the sensor is not reading cause something is covering it or it has poped so it can not reference any longer.
Posted on Oct 17, 2007
This code relates to the ID sensor voltage check which didn't fall between the accepted levels (4V +/- 0.5V). Possible causes: defective sensor, dirty sensor, loose/disconected wire on the sensor, dirty drum.
If you need a manual with further details, it's available here. There's also some other helpful hints for this printer on that page.
Dec 06, 2011 | Ricoh Aficio AP3800C Laser Printer
Error sc385 ricoh 6513
SC385: Vsg Adjustment Error
The LCD displays SC385 when the output from the ID sensor is found to be
outside 1.8 ± 0.05 V during Vsg adjustment.
Turning the power off then on resets this condition. However, SC385 is lit again after the end of each copy job even when this SC condition is reset by turning the power off then on. Toner is still supplied, but using fixed supply mode, until a subsequent Vsg adjustment is successful.
For Starters
· Dirty ID sensor
· Poor connection of connector
· Defective ID sensor
· Poor cleaning
1. Clean the ID sensor.
2. Check if the sensor connector is properly connected.
3. Replace the ID sensor.
4. Check the drum cleaning unit.
Dec 20, 2009 | Ricoh Office Equipment & Supplies
Aficio 6513 ID sensor location / service manual
The ID sensor is located under OPC drum.Clean the optics component,the charge corona ,and see if the OPC drum is good(change every 120000 copies).
Oct 21, 2009 | Ricoh 6513 Copier
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
I have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Nov 10, 2008 | Ricoh Aficio 450 Copier
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh 6513 Service Code 370
HI there I hope it is the colour machine version so below is the description from the service manual.
Thanks J
SC370 Abnormal TD
information (K)
- Timing -
When communicating with
TD sensors, during
printing process, or
process control self-check
- Condition -
TD sensor output exceeds
4.5V or drops below 0.5V.
• Poor connection
• Dirty sensor surface
• Defective TD sensor
• Toner density is out of
• Not enough developer
3-007-001 1. Make sure the TD sensor is properly
2. Check if the connectors on the TD sensor
interface board 1 and the slip ring and the
TD sensor interface board 2 are properly
3. Clean the surface of the TD sensor.
4. Replace the TD sensor. If it becomes OK
after the sensor is replaced, replace the
developer of color related to the problem.
If the problem is related to the toner density
(too low or high), find the cause and fix it.
Jan 23, 2008 | Ricoh 6513 Copier
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
• Defective I/O control
• Defective main control
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Ricoh 6513 Copier Logo
942 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
