Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
How to drain the water lg wf-561spp - LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
heatman101
  • 43501 Answers
SOURCE: LG washer Model wf-t6517te not draining water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 19, 2010
heatman101
  • 43501 Answers
SOURCE: my lg WF-T552TH washing machine will not drain the
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Posted on Oct 25, 2010
  • 146 Answers
SOURCE: I HAVE LG MACHINE MODEL
try to clean the drain filter out,, if that doesnt work you will need a new pump
Posted on Jan 20, 2011
SOURCE: water keeps draining LG WF-561SPP top loader
check drain line for air pocket. .. if there is air in line it will let small water
level in but not a large load ..never hurts to check
Posted on Apr 06, 2013
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
My LG WF-T8018TP Fuzzy Logic is not draining water
kindly check drain motor some forgot items are in side...
Feb 12, 2014 | LG Washing Machines
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
My LG Fuzzy Logic 5.5kg WF-T552TH machine works fine on small loads, but if I put a large amount of washing it, just runs through water and never starts the wash cycle. Water just passes through.
This is a very common issue and simple to fix, the height of your drain hose is too low, it is siphoning the water out of the machine once the water level gets up near the level of the drain hose.
Mar 02, 2012 | LG Washing Machines
I HAVE LG MACHINE MODEL # WF-T706ATT BUT CANT EXPELLED WATER NOW, DRAIN DOESNT WORK ANYMORE...
Jan 20, 2011 | LG Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
