Question about GE Refrigerators
Water dispenser makes a buzzing noise before water comes out
Water dispenser hesitates then makes a buzzing noise then out comes water
5 Suggested Answers
roadbird383
  • 40 Answers
SOURCE: Fridge Makes Cubes But No Water
Sounds like a bad water solinoid valve.
Posted on Dec 09, 2007
  • 958 Answers
SOURCE: Refrigerator Buzzing
if my guess is correct, that buzzing sound could be coming from the evaporator fan touching the ice that builds up in the evaporator. if that is true, a quick remedy for the noise to disappear is to thaw the ice, unplugged it for a while but as ice builds up again, then the noise would come back. the original problem would be the defrost cycle not functioning well. will be in touch if my guess is correct. thanxs,
Posted on Feb 11, 2008
  • 3 Answers
SOURCE: icemaker makes a loud buzzing noise when
If it just buzzes & doesn't actually dispense any ice, you may have a broken dispenser door. We have just had to replace ours for the same reason. We have a Maytag MSD2732GR side-by-side
Posted on Jul 23, 2010
kel1guy2002
  • 3740 Answers
SOURCE: The water will not dispense,
The inlet water valve solenoid has failed. The remedy is to replace the inlet water valve itself. This particular inlet water valve has 3 solenoids on it. You can see the inlet water valve as item 619A this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520906&diagram_id=28703137#d28703137
If your good with a meter... unplug the unit. and slide each of the connectors of the solenoid bak just far enough to check the resistance of the solenoids. They all should have similar resistance. I am pretty sure one of your solenoids had a bad coil.
Thanks for choosing FixYa,
Kelly
Posted on May 14, 2011
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Will not dispense water, but still makes ice
Sounds like either the water valve is bad or the line is plugged or frozen somewhere. To check the valve pull the water line off where the water feeds the reservoir have somebody try to dispense water you should have water coming out.If not try to dispense water again and listen for a slight buzzing noise if you hear the buzzing noise and you get no water the valve is bad.Always check the lines for freezing or restrictions before you replace the valve.
Jun 10, 2012 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag mfi2568aes makes continuous buzzing noise when water dispenser is depressed (sounds like is coming from rear of machine). Water comes out, but at a trickle. Ice is fine
From your description, the only thing I could think that MIGHT cause those types of indications is the dual water value. http://www.partselect.com/PS2069865-Whirlpool-67006322-Dual-Water-Valve.htm?SourceCode=1&ModelNum=MFI2568AES
IF you are sure that the ice maker fills NORMALLY. If it doesn't then I would suspect the filter.
Jun 12, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Samsung DA99-00494V - Water dispenser not working. Thank you
Do you hear a humming or buzzing noise when you push the button? If so but nothing comes out then you probably have a bad water valve. Contact samsung and ask them for the part number. Then try to find that part number online to save a bunch of money. They are easy to change, just make sure you unplug the fridge and shut off the water valve before you start.
Jun 06, 2011 | Freezers
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker makes a loud buzzing noise when dispensing ice.
This would be your dispenser door solenoid making the noise, if left alone with out replacing it may end up causing the control board to fail. The part is number 13 on this diagram. http://www.whirlpoolparts.ca/parts/fspShowPage.php?model=MSD2732GRW&pageNo=17
61005884 is the part number you will need to get.
Apr 18, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Water dispenser makes noise.
Sometimes that happens just before the solenoid that opens your dispenser fails. As the coil weakens they tend to vibrate or buzz. I will search for the part number for your model MSD2655HE Be right back, Sea Breeze
Jan 17, 2010 | Maytag MSD2655HE Side by Side Refrigerator
Machine makes a buzzing noise and does not start when turned on
The buzzing noise could be the water inlet valve which is quite normal. Make sure the water is turned on, If it is, Turn off the water at the tap and remove the water inlet pipe from the back of the washing machine and check that the filter inside is not blocked. Other than that, it could be the vavle itself that`s not opening to let the water into the soap dispenser. Ian
Jul 25, 2009 | Kenmore Washing Machines
Feb 11, 2008 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
