Question about Bang and Olufsen Beosound 2000 Shelf System
Opening a b&o 2500 - Bang and Olufsen Beosound 2000 Shelf System
'99 silverado 5.3 engin will not idle runs at 2500 rpm and drops down to 1000 rpm the back up to 2500 rpm -------------------------
which car is it?
problem with 1993 Geo Prizm '99 silverado 5.3 engin will not idle runs at 2500 rpm and drops down to 1000 rpm the back up to 2500 rpm -------------------------
Apr 15, 2013 | 1993 Geo Prizm
Can not bleed clutch on 1987 GMC 2500
There is still air in the system. Try bleeding the m/cyl first by removing the line to the slave cyl and while holding you finger over the opening have someone gently operate the pedal. When you get good fluid past your finger reconnect the line then bleed the slave cyl. as normal.
PLEASE RATE THIS REPLY FOR ACCURACY
Mar 24, 2013 | Cars & Trucks
Hey . just wondering how do i connect my phonic max 2500 amp to my Numark M6 USB mixer. then i will be connecting my laptop up to the mixer..
The M6 has balanced XLR outputs on the back, which can be connected directly to the XLR inputs on the back of the Phonic Max 2500. You just need two XLR cables.
Feb 20, 2013 | Numark M6usb M6 Usb Four Channel Table Top...
My Behringer 2500 wat pa amp keeps getting hot and cutting off
Step 1:
Overheating is typically caused by poor ventilation. The best thing is to make sure that you --
Step 2:
have plenty of space ALL-AROUND the amp
Step 3:
Fan(s) are working correctly (should always be on).
Step 4:
Boards are clean -- may require opening up housing and spraying with compressed air.
Step 5:
Be sure that the speakers you're pushing are acceptable to amp's output.
Step 6:
If still overheating, may require service.
Jan 07, 2013 | Behringer Music
How many 5 watt outside lights can you power with a 20 amp breaker?
Volts x amps= watts.
20 amp breaker x 125 volts = 2500 watts.
However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
Keep in mind that most switches are 15 amp, and not 20 amp.
Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
Jun 22, 2012 | Home
I have a 1989 Chevrolet Silverado pickup and both the electric door locks and the electric windows will not work. What and where do I start checking first?
power dopr lock/window relay & if fine the wiring between the hinge pillar and the door. They do break open there from opening and closing
Apr 16, 2010 | 1989 Chevrolet Silverado 2500
2001 dodge ram 2500 diesel - my air conditioning blower is blowing but the air is not coming out of any of the vents
the flap inside the vent is not opening you will have to get under the dash and figure out why the lever isnt opening the flap
Dec 04, 2009 | 2001 Dodge Ram 2500 Truck
Umax astra scanner 2500 driver
i want free umax astra scanner 2500 driver thankyou
Oct 31, 2008 | Umax Astra 2200 Flatbed Scanner
Phonic Max 2500 blocked/protected
the problem of shuting down of amp. is some of output driver are shorted or open check the output driver and predriver
Mar 11, 2008 | Phonic MAX 2500 Amplifier
16 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
