Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
I have wirlpool dish washer and it is lock.I cant start it.
  • 23 Answers
First thing to check is the micro switch in the handle assemble.It may be bad.When you shut the door a lever comes in contact with that switch which allows the unit to start.Next would be the thermal fuse(see manual).
Posted on Jul 17, 2009
Child lock
If a button exists for the child lock... hold it down for a few seconds... it might disengage.... worth a shot.... without looking
Jan 16, 2012 | KitchenAid Dishwashers
My wirlpool washer wont spin its not the coupleing the tub is locked up and you cant even move it by hand
Check the block. This is the part that the tub sits on. It is tightened down with a spanner nut
Nov 18, 2009 | Washing Machines
My child safety lock is on my dish washer how do I get it off
For my old GE washer, there was a button with a lock icon. To lock/unlock it, you had to hold that button down for 10 seconds.
Hope this helps!
Aug 03, 2009 | KitchenAid KBLC36FKS Bottom Freezer...
2 year old elect range/oven by wirlpool will not
check your input voltage your probably losing a leg and only have 120volts instead of 240 volts that would cause a reduced heat symptom
Jul 16, 2009 | Ovens
Wirlpool Duet Sport Washer shows no indication of power
That happened to mine I had to replace the "brain" of the washer....the part was about $170. I think it is called the control panel.
There is a test you can run...look in the manual.
Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not cleaning grease off dishes
try this most common mistake made is not getting hot water to the washer on the first wash don't care what brand hot water cleans dishes 130-136 best but you have to bring the hot water to the washer before you start it some lines can run a half gallon to the sink before the hot gets there run the water at the faucet till its so hot you cant stand it then start the washer 0 ohms ok
Mar 11, 2009 | GE 24 in. GSD3220Z Built-in Dishwasher
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
The dish washer won't start
press the key with the lock button for 5 seconds. the lock indicator light should then disappear.
Jun 09, 2008 | Kenmore Dishwashers
Door will not shut
if the stike on the door is not broken then it is the door latch
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
133 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
