Question about Behringer Audio Players & Recorders
I'm in Iraq and I brought my ultratone k450fx with me to play my korg synth and being exciting to finally be able to play I plugged it in without using a transformer and blew a fuse, what size do I need to replace it?
    Problem Solver:
  • 4 Answers
In Iraq I assume the voltage is 220-250.  The fuse you'll need is a 220-240V 1.25A H 250 V.  You can actually use this model without a transformer/converter if you have the voltage selector set to the non-North America setting.
Play well!
Posted on May 17, 2009
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Feb 17, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
Jan 27, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Korg triton extreme synth. L/r outputs work fine by themselves put plug in both right side cuts out using headphone jack instead if you pull the right slightly out of input you get both sides working
I need more info to correctly troubleshoot this. However my best guess from what your telling me is that its either the Audio jack on the Korg or the headphones. If everything else is working properly replace the headphones and the Audio outputs. Post again with more details if that does not work
Jan 05, 2013 | Music
How do i get a key to play repeatly on a korg microstation 61 key just by holding the key down?
No, synths don't have a repeat feature like computer keyboards. You have to keep playing it.
Mar 19, 2011 | Korg microSTATION 61-Key Synthesizer...
I have around $100 to spend on a used digital piano keyboard, and i know nothing about playing, but i would like to learn, like teach myself, i did at one point try to teach myself on a late 80"s Korg...
You will likely have to double that budget to get anything decent... but look for a Yamaha in the PSR series (61 keys minimum). To get a full 88 key, you might have to be up in the $400 range for anything really decent.
Jan 27, 2010 | Korg Ma30
I have a Korg concert piano model c-303. have had it since 1995. Never a problem until a year or so ago. When you turn the power switch on, sometimes it comes on for a while, but then off again. I'm...
You can wiggle the switch around to see if you get any response... You may also want to make sure that you are plugging it in without reversing the polarity. I had one of my synths act up really wierd and scramble the display, etc, until I found I was using a cheap extension cord and had the polarity reversed... the electronics didn't "play well" with this scenario.
If this model has a powerpack on the cord, that may be the culprit as well. If it is just a straight a/c cord, the "powerpack" so to speak, is in the unit and may be going out...
Hope this narrows it a bit for you...
Nov 20, 2009 | Yamaha Full-Size Keyboard
No power
Check the power cord connection from korg up to the power outlet.
Nov 07, 2009 | Korg TR76 76 Key Synthesizer Workstation
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
112 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
