posted by mikri on Oct 17, 2007
need driver
4 Other Users Have The Same Problem
Comment by Guest, posted on Dec 31, 2007
ecran blanc au demarrage
Comment by Guest, posted on Nov 27, 2007
I have a Dell E173FP monitor i have managed to download the driver onto CD but i can't remember how to install it. The monitor is on the default, the properties is not highlighted so i can't update it. Can you help me reinstall the driver 'os these low graphics (640x640) are not only doing my head in but i can't set up my broadband.
Comment by Guest, posted on Nov 16, 2007
driver
Comment by Novtalath, posted on Nov 05, 2007
Modern: there is no driver for vista. Original ones are piece of c.r.a.p. (force 75MHz and you cant set native res for this screen (1440x900)).
This monitor donw want to work with ATI X1900GT.
Best Solution
posted on Jan 26, 2008
you can set a resolution of 1440*900..
option 1) open device manager,, update the drivers for standard vga card.. locate ur video drivers folder,,(do it manually even if u have it on cd)...
option 2) this one is bit risky.... open add new hardware wizard and add ur correct video adapter, no matter ur standard display adapter is already installed. after you finish, update ur original standard display adapter and this time, it will pick the correct drivers.. now you can remove your dumb display adapter and restar pc .
risk is- be very careful, u dont want to remove your physical adapter by mistake, resulting no video after a restart.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 10, 2007
I have found update for Vista, I too was having problems but this patched fixed it up nicely.
http://www.portrait.com/dtune/gwy/enu/upgrade.html
Suggest a new solution for this problem
Post a New problem for Microsoft CHIMEI CMV938D 19 WIDE
Email this problem
Email this problem
Can you Help with these Monitors problems?
Microsoft CHIMEI CMV938D 19 WIDE SCREEN LCD...
Chimei Monitor
Chimei Monitor
Where can i find the power... Answer This...
CAN'T USE DIGITAL CORD
i bought my monitor not long... Answer This...
Chimei CMV 938D 'Out of range'...
I have a 19" widescreen... Answer This...
play back of dvd moving image...
dear sir, i would like to know... Answer This...
Repair Service
Find Monitor Repairman Near You:
