Question about Dryers
Kenmore elite smartheat dryer
Sensing revising est. time error f-01
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: HE5 Electric Dryer: i have a kenmore elite smartheat dryer, but when i...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Smartheat Quietpak 9 HE4 dryer taking longer to dry
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore elite dryer. I just ran a load
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(((())))
My kenmore elite he3 quit working model number DADT-ELE-2406024-EL54 do you know why?
The heating coil safety switch/fuse may have been activated if it got too hot in there. It is very common for escaped lint to finally build up where it should not be. The first thing is to learn how to remove the front of the machine and inspect for a build up of lint. Happens often over time.
Nov 05, 2014 | Kenmore Dryers
The sensing revising est. time light keep coming on and my clothes will not get dry
Could be that the heating element has gone bad or a Heat sensor connected on the side of the Heating element itself. If you can't work on these things your self it will need to be checked by a person who can. If it's very old it might not be worth paying someone to do this. The element may run you $60.00, the sensors maybe two of them are around $15.00 each and the labor?? Ya got a handy neighbor that will help for a nice Apple Pie?
Jan 17, 2013 | Dryers
I have a Kenmore Elite HE5 Electric Dryer, Model 110.8708 The dryer will not rotate when I push the start button, the "sensing revising est. time" lights up amber in the Cycle Status display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 24, 2011 | Dryers
Hola buenas noches tengo una impresora con este error c00e0402, le revise la tapas , atasco de papel y por ese lado esta bien, que mas puede ser, que le hago (ayuda)
buenas tardes,
Prueba estas soluciones de la p?gina Web de HP y de otros usuarios como t?:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1299025019879+28353475&threadId=215818
http://www.fixyourownprinter.com/forums/inkjet/32918
Espero que esto sea ?til
¬°Buena suerte!
Un cordial saludo,
Enolram
Mar 02, 2011 | Computers & Internet
La maquina cuando esta lavando sale f21 y no escurre el agua
F21 DRENAJE DE LARGO
Si el tiempo de drenaje supera los 8 minutos, el apagar las v?lvulas de agua.
NOTAS: Despu?s de 4 minutos, el "SD" error se mostrar?, a continuaci?n,
4 minutos m?s tarde el "F/21" c?digo de error se mostrar?. Pulse
PAUSA / CANCELAR dos veces para borrar la pantalla.
Posibles causas / Procedimiento
1. Revise el tubo de descarga y aseg?rese de que no est? conectado o
doblada.
2. Desenchufe la lavadora o desconecte la energ?a.
3. Compruebe las conexiones el?ctricas en la bomba y aseg?rese de
la bomba est? funcionando.
4. Compruebe la bomba de drenaje de objetos extra?os.
5. Enchufe la lavadora o reconecte el suministro de energ?a.
Dec 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Is there any recalls on the gas tanks of the 2006 cobalts cause my tank is leaking at the top
Fuel Sys, Driveability, Filters (Air & Fuel)
2006 CHEVROLET COBALT
02/01/2006 ELIMINATION OF FUEL FILLER TUBE FLAPPER DOOR 03/01/2006 ERRATIC FUEL GAUGE READINGS 06/01/2006 USAGE OF E85 FUELS IN GM VEHICLES - REVISED 06/01/2006 L61 ENGINE MALFUNCTION INDICATOR LAMP (MIL)/SERVICE ENGINE SOON (SES) LAMP ILLUMINATED WITH DTC P0171 "FUEL TRIM SYSTEM LEAN" SET 07/01/2006 TOP TIER DETERGENT GASOLINE - DEPOSITS, FUEL ECONOMY, NO START, POWER, PERFORMANCE, STALL CONCERNS - REVISED 07/01/2006 USE OF E85 FUELS IN VEHICLES NOT CERTIFIED BY GM AS BEING FLEX FUEL COMPATIBLE / AFTERMARKET CONVERSIONS OF VEHICLES TO OPERATE ON E85 FUELS 09/01/2006 397.pdf&btitle=2006 CHEVROLET COBALT&yr=2006">GM FUEL SYSTEM TREATMENT PLUS, FUEL SENDING UNIT CORROSION AND FUEL SYSTEM DEPOSITS - REVISED 11/01/2006 940.pdf&btitle=2006 CHEVROLET COBALT&yr=2006">ERRATIC FUEL GAUGE READINGS - REVISED 03/01/2006 USAGE OF E85 FUELS IN GM VEHICLES - REVISED 12/01/2006 TOP TIER DETERGENT GASOLINE - DEPOSITS, FUEL ECONOMY, NO START, POWER, PERFORMANCE, STALL CONCERNS - REVISED 01/01/2007 EMISSION RECALL - ENGINE FUEL INJECTORS - REPLACE 01/01/2007 LSJ, L61, LK5, L52, LL8 ENGINE - REDUCED ENGINE POWER, MIL/SES LIGHT, DTC P1516, P2135, P2138 02/01/2007 MULTIPLE DRIVEABILITY SYMPTOMS DUE TO CLOGGED FUEL INJECTORS, MIL/SES DTCS P0171, P0172, P0174, P0300, P1174, P1175 - REVISED 03/01/2007 MULTIPLE DRIVEABILITY SYMPTOMS DUE TO CLOGGED FUEL INJECTORS, MIL/SES DTCS P0171, P0172, P0174, P0300, P1174, P1175 - REVISED 05/01/2007 MULTIPLE DRIVEABILITY SYMPTOMS DUE TO CLOGGED FUEL INJECTORS, MIL/SES DTCS P0171, P0172, P0174, P0300, P1174, P1175 - REVISED 06/01/2007 <A href="http://arrc.epnet.com/autoasp/data.asp?sid=122357497&uid=s9193090.remote.autorefctr&type=pdf&ff=082000
Jul 12, 2010 | 2006 Chevrolet Cobalt
I have a zenith Z62dc1d television that wont turn on. It is trying to power up but wont
revise el cable de poder puede que este partido y le este causando intermitencia
Aug 25, 2009 | Televison & Video
Aug 06, 2009 | Kenmore 600 7965 Dryer
Dryers Logo
Top Dryers Experts
