Question about Dryers
Power serge and now dryer maytag neptune MDE6700AYW will buzz when you push the power button
  • 209 Answers
SOURCE: Dryer stopped working
does this drum go round, if not replace the capacitor which in most models is fastened to the main motor, if this doesn't cure the fault you could be looking at a replacement motor, assuming you have checked for any jamming of the drum, does it rotate be hand as well a working motor will just buzz if the drum is jammed hope i have helped, if so please rate me well
Posted on Oct 07, 2007
  • 1214 Answers
SOURCE: My maytag neptune gas dryer
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Posted on Jan 29, 2009
  • 84 Answers
SOURCE: my maytag neptune dryer has the start button
Did you have any power surges latley? Sounds like the control board is faulty. I think this model has a control board in the top counsel. Hopefully this helps
Posted on Jul 29, 2009
  • 289 Answers
SOURCE: my maytag neptune electric dryer will not work the
first check that you have 240 coming to unit.than let me know.
Posted on Nov 21, 2009
  • 1891 Answers
SOURCE: Dryer has power, all lights come on, however no
first ck the power - turn it off at the breaker box and back on ( you may have lost one leg of the 220 / ) if thsi didn't correct problem it may have over heated due to restricted vent / this causing the safty themo to stop the dryer / it is a one time themo and will require replacement. and vent will have to be cleaned . hope this will help **** ..
Posted on Dec 04, 2009
Testimonial: "Thanks for the speedy reply. The help is much appreciated!"
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune dryer, model mde6700ayw, cycle selector knob will not change cycles. It gets stuck on a random cycle even when I power off, power on. Tried to put in service mode but as the cycle selector...
you have a problem with this dryer,the computer board and other parts are no longer available,your better off replacing the dryer.if you go here you can see the parts
http://www.searspartsdirect.com/model-number/MDE6700AYW/3048/0151200.html?searchType=modelSearch&q=mde6700ayw&searchTerm=mde6700ayw
Sep 06, 2017 | Maytag Dryers
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
I have model # MDE6700AYW (Maytag Neptune electric dryer) Error code T5, service codes 0, 19 and 76. Can anyone tell me what part needs to be replaced?
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Here is a link to the part in case you need it.
Aug 23, 2011 | Maytag Neptune MDE6700A Electric Dryer
My Maytag Neptune dryer flashes an 88 when I push the start button, there is nothing in the manual about solution codes
lack of power did you recently have a brown out or power outage that may have messed up the breaker in the fuse box box
Aug 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
When we push the start button it buzzed but didn't start, now it doesn't even buzz.. it is a push start with the cycle and timer in one.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor has gone bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer has power, all lights come on, however no action. It is a neptune model (p) MDE6700AYW
Dec 04, 2009 | Maytag Neptune MDE6700A Electric Dryer
Getting powerbtpush on button lite comes on but doesn't turn on
you probably have a blown fuse in the dryer. you can check it yourself if you have an ohm meter with tone. otherwise, you will need to call a repairman. Joe
Nov 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
