Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
S-video I BROUGHT A S-VIDEO CABLE SO I COULD HOOK MY COMPUTER TO MY TV AND WATCH NETFIX.. BUT IT DOESNT WORK AND I CANT FIND THE OWNER MANUAL COULD YOU HELP
  • 17 Answers
SOURCE: How to hook up a DVD player
are you conecting video out/dvd to video in/tv and select av on tv.simple. reg'chook.
Posted on Mar 29, 2007
SOURCE: RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Posted on Apr 03, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Computer TV out with S Video
You can use the yellow RCA cable using an SVideo adaptor. When using dual displays make sure that display number 2 is adtive. To do that move the mouse to display 2 press the right mouse button and select active. Check extend desktop to the monitor to check the signal and press apply. Make sure you are using either an Svideo or RCA signal.
Posted on Sep 02, 2008
Gills1
  • 94 Answers
SOURCE: dvd player hook up
If the make and model number of your TV is as stated in the category posted. RCA model 27F530T 27" then you can find the owners manual at the following link.
http://tv.rca.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf
Posted on Jan 04, 2009
SOURCE: What channel do i go to for svideo cable??
The TV doesn't output the TV as such, UNLESS it has what is called a "Monitor" Output Sockets on it. Then you can connect up to, say another "Screen" or Take the Outgoing Video, & Sound, and "Record" it to a PC, via a Video INPUT via a TV/Video INPUT card. BUT you cannot play the TV on the laptop, FROM the TV. like you wish to do. If your laptop has a TV card INSIDE your laptop, then you could use that and display the OUTPUT from that TV cards' tuner, on the TV. But not the "other" way around. That SVHS is ONLY an INPUT out from your PC. You can put you system into either "Cloned"mode, IE: Whats displayed on laptop screen,is also displayed on the TV, Or, you can have as you seem to now, Extended Desktop. I hope this clears things up for you. Also when using that SVHS connection the Audio comes OUT on the Red & White AV sockets on the set. So you need that cable and another pair for the Audio..
Posted on Mar 23, 2010
Fujitsu lifebook a1130 not detecting my TV
check under display settings you may have to enable or identify the monitor manually.
Jun 30, 2013 | Fujitsu LIFEBOOK A1130 LAPTOP Laptop...
I need owner manual for Disney HM950KC karaoke machine
i am trying to connect this to my stereo, the volume is not loud enough, so i bought a split cable, connected to one of my outputs on my stereo receiver. it works but very deep, so i bought a thicker split cable and will try, but not sure how to hook up the video part. a staight wire to the back of my tv? will that work? also i cant find the right kareoke videos, each time I buy one, computer graphics come up but no words, any direction, send to ldeleon@reddyraw.com please
Sep 30, 2012 | Disney Hannah Montana Karaoke System with...
How can i use my acer monitor as a tv i lost my manual
The manual won't help you to much in this regard.
This monitor is a standard type that has both a VGA and DVI input.
Normally what you would use with a personal computer.
If you want to use it as a TV monitor you will have some sort of device that outputs to VGA or DVI.
DVI stands for "Digital Visual Interface" and it's preferable over VGA as it should potentially give you a better image.
This means:
A) A computer. You can build your own media TV and watch internet streamed shows like Hulu, Netfix, use as a DVD player, etc. I recommend this route. No more dependance on Cable companies! You just need internet.
B) Find a DVD, and, or Tuner/Cable/Satellite box that has these outputs.
If you want to use Cable or Satellite, contact your provider company and see if they have a box that will output to either VGA or DVI. Might have a hard time finding one of these, or it might cost more then it's worth.
C) Buy a S-Video input to VGA/DVI output. You can buy these for around $40.
Then you should be able to hook it up to just about any device as most modern TV devices will have an S-Video outputs.
Feb 17, 2011 | Acer AL2032WD 20" Flat Panel LCD Monitor
Ps3 not wworking on regular TV after hdmi cable was used.
sounds like you have the ps3 set up in HD video display settings?
If this is the case hook it up to the regular tv and when you turn the power on continue to hold down the power button til it beeps this restores the video to default settings sometimes it takes a 2nd power down and power up holding it down to work.
If this doesnt solve please give more details
May 02, 2010 | Sony Playstation 3 (PS3) Console
I hooked it up the way the manual said and it doesnt work
Try whatever applies best below, in order...
Cable Box optical Digital Audio to Digital Audio In. (This brings TV-related multi-channel and normal audio into the receiver so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the system on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box HDMI, Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
May 01, 2010 | RCA RT2380 Home Theatre System System
I have an apex dvd vcr tv the vcr doesnt work vcr doesnt work how
Video out on tv ? If yes just standard rca cables and vcr in video input mode. If no then you`re out of luck.
Nov 03, 2009 | Apex Digital AT2002S 20" TV
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Go to this link; http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Mar 29, 2007 | RCA F32450 32" TV
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
