BafoTech BAFO BF-1284 Parallel Adapter
Initialization failed - Unable to acquire...
shared by 3 users
posted by prakjobs on Oct 17, 2007
This message "Initialization failed - Unable to acquire TWAIN-compliant device" display when i'm trying to scan using a BAFO-1284 USB-PARALELL cable connected to a Panasonic UF-4100 3-IN-ONE fax/scanner/printer with my laptop. Please note that printing is working perfectly.
Thanks.
Comment posted on Oct 17, 2007
Thanks for your help, but I dont have any paralell port in my laptop - meaning I can't use the 3-in-one fax/scanner/printer to scan.
Prakash
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on Jun 06, 2008
the document manager was unable to acquire twain compliant device
on a a shared network but yet i am still able to print can n e 1 help me
Posted by arka_2529 on Apr 22, 2008
same Problem
Best Solution
FixYa! (100)
thumu
Rank:Guru Guru
Rating: 86%, 107 votes
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Rating Locked! (?) prakjobs has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Initialization failed - Unable to acquire TWAIN-compliant device:
I don't want to Accept this solution
Can you Help with these Other Network Devices problems?
My smcRouter has blocked an ip, and i cant find the,...
In my home, I have two computers. One is a desktop wired...
i need operation manual of bts used ofr mobile...
hgfbehgcnkbcbghsadfgyeg
pls send me the manual or descripton of NOKIA Flexi BTS...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Other Network Dev. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
