Question about iHome iDM12 2.0 Speaker System - PMPOWireless Speakers - 30 ft - SRS
Need to open an ihome idm12 - iHome iDM12 2.0 Speaker System - PMPOWireless Speakers - 30 ft - SRS
2 Suggested Answers
SOURCE: how to take apart
The port was broken on mine also. I looked online and found no help so I decided tear it apart since it was broken anyway. There are 6 phillips head screws located under the speaker cover. The black mesh material is glued down so you have to pry it up and then peel. The backing tore on mine so it will be a challenge to actually remove it without damaging it. Once it is off, you can remove the 6 screws and it will open right up. The charger port is located inside a small black box that is held down by 2 screws. Once I got to the little charging port, I found that it had become separated from the circuit board and couldn't be put back on. Not unless you know how to solder or do circuitry. I figure it isn't repairable.
Posted on May 07, 2013
How do I open my iHome IP46 to replace battery?
Try Googling (iHome)(IP46)(manual) without parens.
Jun 19, 2017 | iHome Audio Players & Recorders
Tip
How to connect an my iPod Nano 3rd Generation to an iHome
<p>Your iPod nano to a device like the iHome to boost output audio or video to a TV in your memory. The iHome also charge your phone as it is docked. You need to take steps to ensure that your iPod will be able to successfully dock the iHome. Once your iPod is well prepared, so you get the most out of your drive for iHome. <br /> <p><br /> <p>1. Connect your iPod to your computer and launch iTunes. <br /> <p><br /> <p>2. Click "Help" from within iTunes, click "Check for Updates". <br /> <p><br /> <p>3. Select "Yes" when asked if you want to download and install updates. If no updates are available, disconnect the iPod. <br /> <p><br /> <p>4. IHome Connect your unit to an AC outlet. <br /> <p><br /> <p>5. Remove the protective layer of your iPod Nano, if applicable. <br /> <p><br /> <p>6. Let the iPod Nano in the dock with the front facing you. You will feel it snap into place. <br />
on Jul 21, 2011 | Computers & Internet
How do i open up my ihome id9 to replace the battery
You have to remove 5 screws located under de black rubber cushion on the bottom of the ihome id9, you may need to glue back the rubber. Peel it off carefully to avoid tearing it apart .
Jan 18, 2013 | iHome iD9 Portable App-friendly...
How to take apart
Dec 27, 2012 | iHome iDM12 Rechargeable Portable...
How to take apart idm12 ihome speaker
Pry the front grill cover from the edges. There will be 6 screws to remove before it will come apart.
Nov 24, 2012 | Audio Players & Recorders
Need user manual for iHome iH9
The iHome site has the manual for the iH9 on their product page: https://www.ihomeaudio.com/iH9P6/ . The direct link to the manual is https://www.ihomeaudio.com/media/uploads/product/files/iH9_IB.pdf .
I hope this helps.
Jan 25, 2012 | iHome Ih9 Ipod Station
Hi I have an iHome alarm clock/radio that has an ejectable outlet for the iPhone/iPod/ etc and after one drop to the floor, the piece that reads iHome broke off and the ejecting piece does not push out by...
sadly this devices are no longer sold
you should try to find a damaged iHome and use for replacements or find a used one to replace your actual device
ihave an iHome too, and i had made some tricks to keep it working
Mar 22, 2011 | Audio Players & Recorders
I need a driver for my webcam ihome IH-W313NR ? I
Instruction manual
http://www.life-works.com/product_files/iHome%20MyLife%20Webcam.pdf
Ihome - Mylife drivers
http://www.ihomecomputer.com/404.asp?404;http://www.life-works.com:80/drivers
Sep 15, 2010 | Computers & Internet
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
iHome iDM12 2.0 Speaker System - PMPOWireless Speakers - 30 ft - SRS Logo
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
