Question about Sony KP-FX532M91 TV
10 blinks, TV not switching on - Sony KP-FX532M91 TV
Panasonic tc-p50u1 10 blink code
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 23, 2016 | Panasonic TC-P50U1 Plasma TV
Why my Sony Wega tv standby light blinks 10 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 23, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
10 blink code
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Panasonic TCP42G25 42 in. TV
Blinking blue power light
These blinks are fault indications. Count the number of blinks occur at one time switch ON. From the number of these blinks, you can get an idea about the faulty circuit side in the TV. You must have some knowledge in electronics to follow. If you have confidence, check the link. It has details about the blinking codes to JVC TVs. http://electronicshelponline.blogspot.com/ Make sure about the number of blinks, before you proceed. Switch the TV On and OFF for at least two times to make it confirm. Pull up older posts by that site, by its left sidebar.
Jun 14, 2013 | JVC LT-42X579 42 in. LCD TV
WHY MY panasonic tc-50ps14 IS BLINKING A RED LIGHT 11 TIMES AND HOW I CAN FIX IT?
I have a 10 blinks and 12 blinks for that set, 10 says it possible SC board, and 12 says
Unplug the TV and disconnect connector A11 from the A board. Plug in the TV and press the power switch
Does the TV power up and
stay on?
No
Yes
If the speakers wires
are not pinched,
Replace
the speaker
Replace
the A board
Jan 16, 2011 | Panasonic TC50PS14 Plasma TV
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
I lost the manual and i dont know how to program it please help its an older direct tv remote?
10 Steps to Program Your Directv Remote
1. Turn on television.
2. Locate the switch at the top of your remote that allows you to toggle between receiver, auxilary, and TV modes. Slide switch over to"TV".
3. Hold down MUTE and SELECT until a small green light at the top of the switch blinks twice.
4. Enter code 9911.
5. Press and release the CHANNEL UP button repeatedly until television turns off.
6. When TV turns off, press SELECT.
7. Next, press the power button. This should turn the TV back on.
8. With television on, press and hold down MUTE and SELECT again until the small light blinks twice (same as in step 3).
9. Entercode 960.
10. Slide switch back over to "DTV". Your remote is now ready to use!
Jul 01, 2010 | Philips DIRECTV R15
SONY KP-FX432m91 PROJECTION TV 10 BLINKS OF STBY LT
tyoe in google bar understanding sony blinking codes.
Feb 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony KP-FX532M91 TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
