Back to:
Tags:
Sony VPL CS5 Multimedia Projector
Sony VPL CS5 Multimedia Projector Problem
posted by tsegay on Oct 17, 2007
Hi my partner I have VPL-CS5 data projector when I connect to my LG laptop and turned on the projector, it goes well for some minutes the light emiter hall opens after some minutes it freezes down and closes the opening and lastly turns of it self.Is there any one willing to help me please?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 07, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The Temp/fan light is on and is shutting down the projector what do I do
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sony VPL CS5 Multimedia Projector Problem:
I don't want to Accept this solution
Solution #2
posted on Feb 26, 2008
Not Rated (0)
gaz1958
Rank:Master Master
Rating: 86%, 10 votes
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Thank You!
Can you Help with these Multimedia Projectors problems?
i have sony vpl-cs5 data projector & it will automatic...
When I hook up my hp laptop (widows xp home edition) it...
Hi The projector show most of the time " unaplicable...
I have a sony vpl-cs5 and all worked fine until the image...
the image apears out of convergence , i see the image, and...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
