Question about smilebox.com
Loading first song and it stopped at 99% has not moved for a hour. will i lose my whole file if i shut down
Can't download songs all of a sudden. Says check file configuration and I have no idea what that means. Help please!
means the file wher your songs used to down load to has been deleted or moved if you like i could fix for you free of charge just let me know
Jan 28, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Have down loaded itunes and it stops ay 99% i have
If you are trying to download the upgrade from the itunes program itself, it will sometimes disconnect.
You may want to just downlod the file itsetlf from this website:
http://filehippo.com/download_itunes_32/
-please Thumbs up if you find this helpful
Apr 07, 2011 | Apple iTunes
I have iPod Nano 2Gb . If I play music each 10sec music stop and start new song. I can not arrive to eliminate this mistake.
This worked for me.
1. Locate the actual song file. You can check this in iTunes, use the 'Get info' command, in the summary tab, there's a 'where' item at the bottom. Mentally note that this is 'file#1'.
2. Once you've find the file, make a copy of this file in some other folder. Or maybe even on the desktop. Mentally note that this is 'file#2', which is a copy of 'file#1'. Do not rename.
3. Go to iTunes, and delete the problematic song. If iTunes ask to remove the file, click 'yes'. If iTunes doesn't ask, manually remove the file from the original folder. You are removing 'file#1'.
4. Once this is done, move back the copied file, ie 'file#2', to location where 'file#1' was.
5. Add the song back into iTunes. iTunes will treat it as a new song. You will lose some data like Rating or Play Count. You might need to add some details like track number and so on.
6. Sync your iPod. Done.
You have to do this steps to every problematic song. Tedious, yes. But it's better than the need to re-encode the files.
Mar 28, 2011 | Apple iPod nano
Two problems 1)My sansa clip shut down on its own and when I turned it back on all files were erased. When plugged into the computer the media player still showed 3/4 of the memory still used on the clip...
Its not usles, you can delete the files while on the computer. After having in plugged in you can access it like a flash drive. Then you can open the music folder and delete as you will. Depending on what kind of files you have on it, its possible that i wont recognize the format of the file. I think though from what you've said that it did work, and then stopped playing songs that worked before. So I don't know what to do about that. I don't use the normal way of loading songs onto my Sansa clip MP# player though. I just dump all of my songs via direct transfer into the music folder in the player itself
Oct 04, 2009 | SanDisk Sansa Clip MP3 Player
Won't show loaded music
open mp3 file and totom music file and copy accross one song , close pages and shut down tomtom s/w , disconect from pc and turn on goto album that song should now be listed if it plays you will need to repeat procedure for the rest of songs not 1by1 but all.
Apr 17, 2009 | Tomtom GO 910 GPS Receiver
Won't turn on
Tetasonja40 , your problem may be the same as some of the other players. IF you don't have a license in the music you are copying the player loads it and it is visible but will not play and may even lock up the unit that it will blink on then when you hit play it shuts off or the light remains on but solid and will not play. Try removing the songs one at a time till the offending file releases the unit. I spent hours resovling this on other units. another problem that occurs is the players stop recognizing mp3 files for replay. converting them to a wma may resolve this problem.
Jan 31, 2009 | Coby MP-C883 MP3 Player
Motorola ROKR z6m Media Player Not Functional
Okay, now this goes for if you can't see your pictures as well.
You need to make sure that there are not files for each song. Go onto the memory card and if there are folders for each song, move the songs onto the card 1 by 1 and delete the folders. It seems as though the folders are tricking the phone and making it shut down. The phone cannot process that many folders.
Once this is accomplished, you should be able to opperate like it should be.
Folders are created when you sink your media player to the phone, don't do this!
Move the songs over 1 by 1 to the music folder preinstalled on the memory card once formatted by the phone.
Dec 08, 2008 | Motorola Mobility ROKR E6 Smartphone
FILE ISSUES
You can format the whole player..and that will delete everything off the player...use windows media player to format the player....once you format you shouldnt have any songs in there...
Dec 30, 2007 | SanDisk Sansa E280 MP3 Player
Power light is on but there is no display
Taking out the battery would do just as much harm as holding the power button down would. This could make you lose some memory or even corrupt important files. But if you have truly tried everything else (even holding the power button down until it shut off) and it still did not shut off then you would need to take the battery out to be able to try and fix it.
If possible, I would take it to a computer shop to avoid the possible corruption of your important files.
Dec 29, 2007 | Acer Aspire 5630 Notebook
Certain songs on my iPod that I bought with iTunes just will not play when I upload them
Do they play ok in itunes?
Try resetting your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 26, 2007 | Apple iPod MA446LL/A MP3 Player
smilebox.com Logo
19 people viewed this question
Top smilebox.com Computers & Internet Experts
ray gallant
Tony Mitri
Are you a smilebox.com Computer and Internet Expert? Answer questions, earn points and help others
