Question about LG LFX28978
Lfx28978st french doors don't close properly
LEFT DOOR LATCH
  • 958 Answers
SOURCE: lg french door fridge
do you have mechanical button switch that should close the light if you close the door?... they could be defective. try to look for these button switch that the doors presses as you close them. if they dont have, then they may be using a magnetic door switch which would be very hard to locate and trouble shoot.
Posted on Feb 13, 2008
22yooper
  • 828 Answers
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
  • 28 Answers
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Posted on May 09, 2009
SOURCE: Our French Door model after almost 2 yrs pops open
We solved this problem by replacing the plastic parts on the top & bottom of the door that 'latch' the door closed.
On the top of each door is a white plastic 'cam' that latches into a receiver at the center point of the refrigerator chamber. One of mine was broken.
Additionally, on the bottom edge of each door is a white plastic hook-shaped 'stopper' that provides spring tension. I replaced both of those and now all is happy.
Got the parts from RepairClinic.com
Item #: 1266811
Description: Door hinge cam (left)
Price: $2.40
Item #: 1266810
Description: Door hinge cam (right)
Price: $2.40
Item #: 1267543
Description: Stopper,door
Price: $2.40
Posted on Oct 31, 2009
SOURCE: The right hand side of the French door of LG makes
Don't put too much stuff on the shelves, they will sink the door. It is OK now. Haliluya
Posted on Dec 01, 2009
My oven is locked. Display shows F5:E7 How do I unlock it?
Vera, Code F5 E7 your latch assembly has failed. Turn oven breaker off to the unit for 5 min. to see if it will reset. If not, then try to set the self clean, wait 1 min. and cancel it to see if that will reset the door latch. If it does not reset the door lock, then you will have to manually open the door and replace the door latch assembly. It's not easy task to unlock the door. You'll need to use a coat hanger and pull the latch assembly from (right - left) by slipping it down between the door and the oven top. Force the latch over to the left and open the door, then you will have access to remove latch.
press the helpful button and follow me on fixya for more tips and info
Appliance411 FAQ After self clean range oven door won open
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0ahUKEwj-qYvv3ffKAhVHKh4KHdaUBgAQtwIIKTAD&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D320yZMp34oA&usg=AFQjCNE0dH2xRKfdY8alz0y7MdjMT86ULA
http://products.geappliances.com/appliance/gea-support-search-content?contentId=16246
How to Troubleshoot the Door Lock on your Stove Range
Feb 14, 2016 | Kitchen Ranges
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
How do I replace the door latch?
A good place to view exploded parts diagrams is Sears Parts. See http://www.searspartsdirect.com/samsung-refrigerator-parts/model-RFG297AARSXAA0000/1482/0161000.html. Note that the parts you are looking for could be in the left door diagram or mor likely the cabinet diagram.
Aug 05, 2015 | Samsung RFG297AARS (285 cu ft) Bottom...
Leaking door
Open the door and look inside at the lower left corner where the door gasket ends. See if there is any type of obstruction or foreign object in that corner. It doesn't take much to cause a door leak. Some door latches can be adjusted tighter. Look at the top door latch system and see if has 2 screws in it. You can sometimes loosen the screws and push the latch inward slightly and re-tighten the screws. That will make the door tighter when latched. Not all dishwashers have adjustable latch systems.
Apr 04, 2015 | Dishwashers
Water dispenser
Make sure the freezer door is closed
Make sure the water is turned on, a valve on the wall behind the frige.
Make sure the filter is good.
Mar 27, 2014 | LG LFX28978ST 27.6 Cu.Ft. French Door...
2008 GMC 2500 Cargo Van Dash keeps sayin lr door is open and it is not!!! Driving me crazy!!
the latch in the left rear door is either bad or stuck, open door, then with a screwdriver, rock latches in door to simulate closed. release with exterior handle. spray lubricant (WD40) into latches and continue to exercise the latch. if this quick fix does not work, then a new latch for this door may be needed.
DW Mylin
Nov 28, 2012 | 2008 GMC Savana
Plastic latch on left french door broken
Go to www.partselect.com put your model number in, click on the diagram. For the door. Should be part #PS1016086
/uploads/images/9_1_2014_3_03_11_am.png
Jan 30, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
LG LFX28978 Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
