Question about Frigidaire Dishwashers
Frigidaire Dishwasher GLD2250RDC6 Won't Drain
The water pools at the bottom, I cannot figure out how to fix it. Please help. Thanks!
  • 183 Answers
SOURCE: shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Posted on Aug 05, 2007
NJFIRESTORM
  • 84 Answers
SOURCE: Frigidaire Dishwasher
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Posted on Jun 20, 2008
jbjaxiis
  • 95 Answers
SOURCE: The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Posted on Jul 06, 2008
heatman101
  • 43501 Answers
SOURCE: dishwasher did not drain all the water
The house drain is clogged...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: Water Stayed in dishwasher
heatman101
Dishwasher won't drain
Good Morning Jean,
I see that you are having trouble with your Frigidaire dishwasher, model# FFBD2411NS, draining. There are a few things I would suggest:
1) If the appliance is hooked up to a food waste disposer, make
sure the disposer is empty.
2) Check to see if the knockout plug has been removed
from inside the food waste disposer inlet.
3) Check to see if drain hose is kinked.
4) Check the glass trap filter to see if anything is preventing the water from draining.
5) Overfill Protector should move up and down freely about one inch. If it does not move, lift and clean underneath. Clean occasionally with
household cleaner containing vinegar or bleach to dissolve any buildup.
If none of these suggestions help your dishwasher to drain the water, I suggest contacting your local authorized technician.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire FFBD2411NS
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Model # FFU14F9GW.. water pooling under unit
Greetings,
If the water is pooling under the bottom drawer. I'd say your drain is clogged..the drain will freeze over from something getting into the drain i.e. food particle....The best thing to do. Is use a hair drier to defrost the drain pan and then make sure your drain runs free by pouring water into it....
if this is pooling under the refrigerator and out on the floor..There is a drain pan problem..and /or the drain hose going to pan is out of the pan , or has a hole in it...correct as needed
If this has been helpful in fixing your problem..please leave a testimonial.....thank you
Dec 12, 2010 | Frigidaire Freezers
Is a small pool of water in bottom after dishwasher has finished
check the air gap for the blockage,or the underneath of the pump screen
Jul 31, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Sitting water in bottom of dishwasher, not draining or cleaning. How do I fix it? Thanks
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Jun 20, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Our Frigidaire Refrigerator will not drain water
I have the same exact problem - hoping to find an answer today - please post if you find something
Jan 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire dishwasher PLD2854rdc2 Water seems to pool up at the bottom an never completely drain out. I have cleaned out any accumulated food but doesn't seem to drain.
you are supposed to have a small amnt left in bottom about 1-2 inches it keeps the motor seal wet so it will not dry out and create a leak that could cause more damage
Dec 25, 2009 | Frigidaire PLD3460REC Dishwasher
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Where is the drain screen at in my My frigidaire dishwasher
generic reply normly in the center and looks like a plastic grating, but is your drain hose kinked?
Oct 25, 2008 | Frigidaire Dishwashers
Not draining
the drain pump is separate from the was motor and is accesed from underneath the dishwasher that help wash moter is one piece and is replaced as a whole unit and the drain hose comes from the factory making a loop up side the tub a lot of installers cut the ties holding the loop to get more drain line if loop is removed will loose its prime and stop draining or drain some times and not others when you first start the dish washers it drains then fills so you should hear the drain pump rum if something isnt jamming it
Dec 30, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
27 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
