Dimplex lpc heater doesn't shut off - Heating & Cooling
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
I have lost the brochure for my heater, the Dimplex Eco 2.4kW 11 Fin Column Heater.how do you set the timer?
Emily, if you live in the USA, contact Dimplex Technical Service 888-346-7539 for that information, as well has getting a replacement Owners Manual.
Apr 18, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
I have a dimplex springbourne fire and the heater shuts off after it has been on for a short time what is the problem with the unit
Apparently, the heater is overheating and the overload switch is shutting the heater element off.
Contact Dimplex USA Technical Service at 888-346-7539 for assistance in solving this problem.
Mar 07, 2011 | Heating & Cooling
Will someone fix my fireplace,it sparked and zapped then I shut it down
If it's still under the 1 year Manufacturer's Warranty, Dimplex will repair or replace at their option. If not within the warranty period, unfortunately, you're on your own.
You can contact Dimplex USA Technical Support at 888-346-7539, Monday - Friday,8:00 a.m. - 4:30 p.m. EST. They can help you trouble shoot the problem.
Mar 03, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My Dimplex model #6901470100 (purchased new in 2007) just stopped working. It was on then just turned off by itself. Both lightbulbs are OK. What would cause this?
It probably overheated and the overheat module shut the heater down. It may reset itself once it cools down. Or the heating element has burned out. There are a host of issues with these electric fireplaces (not just Dimplex). They are sold as a decorative, supplemental heat source, but in fact, if you get more than a years use out of it without a problem, you're probably the exception. The heaters just aren't meant to run for a long period of time. It's like turning on a blow drier and letting it run for an hour. Nine times out of ten the blower driver will overheat and burn out.
I really wish I had better news for you (I answer this type of question at least 5 to 6 times a week), but I don't.
The only good news would be, if it's still under warranty (one year), have your Proof of Purchase and contact Dimplex USA. Technical Service: 1- 888-346-7539. Customer Service: 800-668-6663
Feb 23, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
