Question about Bogen C20 - Mixer Amplifier/classic Series Classic Series 20 Watt
How do i connect raw speaker wires to bogen gs150
I have $ microphones and I need to connect them directly into the amplifier (not with xlr connection)
How do I connect Active speakers to my Denon 3805 AV receiver?
Your Genelec 1037C monitors are professional design with balanced inputs. Balanced inputs expect a low impedance signal with pin 1 earth, pin 2 hot and pin 3 cold. Because the Denon amplifier supplies a pre out for the front speakers (the first pair in the set of pre outs) at 1.2 volts and high impedance, you will need to convert the signal close to the amplifier with a stereo active DI box. Plug the pre out directly into the input of the DI with a SHORT lead and then plug two standard balanced microphone type cables ( XLR to XLR) into each of your active monitors. You cannot make a cable that is RCA to XLR by shorting pin 3 to earth to do this job properly. The inputs on your Genelecs expect a signal in the range -6dBU to +6dBU for rated output. A suitable DI box would be for example a Klark Teknik DN200. Hope that helps.
Cheers, Don.
Dec 06, 2014 | Denon AVR-3805 Receiver
My spd s has a bussing soud...I have change the cable and still the same problem
I was using a 25 foot 1/4" to XLR cable from the back of the Roland directly into the Thump. As mentioned, I tried going from the Roland to a direct box with a 1/4 cable on both ends; then out from the direct box "thru"-1/4 fitting, to the XLR connection in the Mackie Thump, with a cable that had the 1/4 on one end and the XLR on the other. Still buzzing. So for grins, I hooked an XLR to XLR cable from the Direct Box Low-Z out, to the Mackie Thump, keeping the 1/4 plug going from the Roland to the Direct box and eliminating the "thru" connection from the direct box to the Thunp, (1/4 to xlr). NO BUZZ.
There is a definite loss of signal strength, ie: everything is coming through quieter, but I can raise the volume of the Thump to FULL, with no buzz, and I can raise the volume of the Roland Module to full, and still no buzz. But there is a definite loss of overall volume, I think because I am not using the direct box properly. Hmmmm. As I understand the Direct box, the IN and THRU are supposed to be used as I was, going from the Roland module to the IN, then from the THRU to the speaker. The Low-Z outs are supposed to carry a signal to a mixer, I suppose to use a FOH PA system, or for recording purposes. Still, I have no buzz. Now...........
In looking over the cords, I suddenly realized that the 25' 1/4" to XLR could be the problem. The 1/4" plug is STEREO! Not mono. Could this be the cause of my buzz? I'm thinking I have a stereo plug, so 2 wires are involved, yet I'm using it in a mono imput in the roland. Perhaps this is creating my ground loop?
After getting a 1/4" MONO to XLR adaptor, attach it to my XLR to XLR cord, go from the back of the Roland (1/4") to the speaker directly (XLR) and see if my buzz is still gone.
The problem now becomes going from the Direct box to the speaker, since it needs to be 1/4 mono from the box, and xlr male to the speaker. I cannot locate a cable like that! So, I guess the next best solution is to get an adaptor to convert one end of the xlr/xlr cable to a 1/4 mono plug. At that point I don't think the cable would still be considered a 'balanced' line though, since it goes from 3 wire at the xlr to 2 wire at the 1/4 ts plug, right? The only other solution is to continue running out of the direct box as I am, using the Low-z out xlr connection, so I can continue to use the xlr/xlr cable.
Also there was a button on the direct box, called a PAD, for -15dB, I assume that what was causing my signal attenuation. When I pushed it in and it released, I suddenly had my volume back.
May 08, 2012 | Roland Spd-S Sampling Percussion Pad...
I bought a ddu250 and an xlr connector for it. I looked at the picture of the wiring diagram and it has the White wire going to pin 2, the black wire going to pin e and the shielded wire going to pin 1. ...
does this mic have a switch? Is this mic dual impedance? If it is dual impedance depending on the impedance of the input will determin if you use 2 or3 wires. If it is only low impedance then white to pin2 black to pin 3 and the shield to pin1. If it is low imlpedance and has a switch the red and blue wire may be connected at the switch and may also have to be conneceted to pin2 and3. any more questions call me a the store.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
servicedepartmentprolinemusic@comcast.net
www.prolinemusic.com
Jul 14, 2011 | Bogen Communication BOGEN DDU250 DYNAMIC...
What are the true xlr connection numbers for bottom blue and red wires
Blue wire connects to XLR pin 2.
Red wire connects to XLR pin 3.
You can find a wiring diagram on Shure's website.
Apr 19, 2011 | Shure SM58 Professional Microphone
I have a superlu pra-h7a. I also have a cable that connects to the bottom via a three pronged male plug with with a female connector on the other end. i have not used this in years, and can't remember how...
You need to connect it to a mixer first and from there to an amp/speaker combo. This microphone needs phantom power and you can only get it via the mixer. Also, you can control the volume via the mixer. Depends on what kind of speaker you have (active or passive) you will need an amplifier. If you're trying to plug it into a guitar amp, it won't work without a mixer. Plug the 3-prong xlr male cable into the input of the mixer. The 3-prong female xlr end goes into the mic.
Oct 08, 2010 | Superlux PRA-H7A Professional Microphone
Hooking up 4 microphones for a bogen GS60 amp
Essentially, you DON'T !!!
If you need to connect four mics, they should attach to the four XLR type connectors.
The terminal strip above is only for TWO mics.(#5 and #6)
For those you connect the SHIELD to the middle terminal of each under the "MIC5/6" labeled "GND". The each of the BALANCED microphone lines for the two extra mics go to the left and right terminal beside the respective GND terminal.
Nov 08, 2009 | Bogen Communication GS35 Amplifier
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
Bogan DDU250 Decktop mic
the tip is is soldered to 1 and the sleeve/ring is soldered to 2 on a xlr. thanks nate. i have pictures i can email you if you need more.
Aug 21, 2008 | Bogen Communication BOGEN DDU250 DYNAMIC...
RE:simple hook up proceedures
Well first off u must be doing some nice recordings or live sound but anyway. On ur back panel those r called terminal strip connections. For hooking small mini wires. For every mic u have and want to hook up to the rack u will need Mini Barrier to XLR adapters and one for ur main output to ur mixer or amp.
Apr 10, 2008 | Audio Players & Recorders
Bogen C20 - Mixer Amplifier/classic Series Classic Series 20 Watt Logo
112 people viewed this question
Top Bogen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bogen Audio Player and Recorder Expert? Answer questions, earn points and help others
