Question about Sony Bravia Kdl-46ex500 Hdtv Compatible Full Motion Articulating Tv
Dead set no lights bravia KDL 46ex500
Dead set
xCAUSALITYx
  • 210 Answers
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Posted on Oct 09, 2009
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
  • 21 Answers
SOURCE: I have sony Sony Bravia
check is source is 4:3. set tv widemode to full.
Posted on Oct 18, 2010
  • 2246 Answers
SOURCE: Frequently, My Sony BRAVIA XBR KDL-V32XBR1 32"
change your tv mainboard
Posted on Jan 09, 2011
  • 25 Answers
SOURCE: Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Posted on Jun 28, 2011
How many chain link do I count to set the timing
When you are setting timing you are setting top dead center and bottom dead center. Once established based on the marks on the crank and cam you adjust top dead and BDC by degrees in ADVANCED timing or behind/retarded timing by degrees by counting links. Each link used to be 5 degrees. Check repair manual on link values! they change with each engine and maker.
Sep 04, 2016 | Cars & Trucks
Tip
Need For Speed Shift Keyboard tips
For anyone who uses keyboard in playing NFS Shift try one these settings.
Steering Dead Zone-15%
Accel Dead Zone-10%
Brake Dead Zone-10%
Steering sensitivity-5%
Acell Sensitivity -5%
Brake sensitivity-5%
Speed steering Sensitivity 100%
Steering Dead Zone: 50%
Accelerator Dead Zone: 25%
Brake Dead Zone: 5%
Clutch Dead Zone: 10%
Steering Sensitivity: 100%
Acceleration Sensitivity: 40%
Braking Sensitivity: 50%
Clutch Sensitivity: 40%
Speed Steering Sensitivity: 0%
Inverse Shifting: Off
Camera Y Axis: Normal
AI Difficulty: Medium
Handling Model: Normal
Steering Assist: Low
Braking Assist: Off
Anti-Lcok Brakes: On
Traction Control: Low
Stability Control: On
Damage Effects: Full
Gears: Automatic or Manual
At least anyone can now enjoy the game without having the hassle of wheels and other devices cluttering up their desk.
These settings work well in the new 1.02 Patch hope these helps.
on Dec 15, 2009 | Video Game Consoles & Games
Sony kdl-46ex500 2 red power blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Nov 29, 2015 | Sony KDL-46EX500 46" Bravia EX500 Series...
I have a 5 year old Sony Bravia kdl-46ex500 that is almost always bright green. Changing inputs does nothing, no menu or any information on screen, no blinking lights, just fully green. It used to be that...
Hi
this is a common mode problem which are open these choke coils are located near LVDS connecter & total 6 coils are change then your led will become other wise change complete system board
Mar 20, 2015 | Sony Televison & Video
Is there a fix for poor audio quality on KDL 46ex500?
Do a factory reset to this set, and check. If it do not help you, check its speaker/s. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 21, 2015 | Sony KDL-46EX500 46" Bravia EX500 Series...
My sony bravia kdl 46ex500 turns off and in by
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 21, 2014 | Televison & Video
When i turn on my kdl-46ex500 sony tv the screen will flash on and the sony emblem will appear then the tv will shut down you can do this several time still the same out come
You were smart not to let yourself be ripped off. Try this. Unplug and replug the set in powered down status. Then turn on and off using the remote. Then, one by one, actuate every button on the remote, then turn set off, even if already off. Then turn set on. See how the set works now.
Aug 21, 2014 | Sony KDL-46EX500 46" Bravia EX500 Series...
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Sony Bravia Kdl-46ex500 Hdtv Compatible Full Motion Articulating Tv Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
