Question about Sharp R-1405 / R-140 Microwave Oven
Crack in the door
Sharp carousal microwave over the stove has a crack in the door. Model number 1491, serial number 125338
  • Sharp Master
  • 9,047 Answers
You can order separate panels for the door as opposed to whole door, assuming they are still available.
We have the service / repair manuals for this model and have uploaded them to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 20, 2009
Where is the monitor switch located on a sharp carousel R-4X06 microwave?
Hi, if this unit is over the stove it has to come down. Table top, case has to come off. The monitor switch is a microswitch that is part of the door switches. PLEASE UNPLUG YOUR UNIT BEFORE WORKING ON IT. When you get it opened up, there's probably a diagram that will let you know which switch it is. Lookd it up and does list a monitor switch with fuse, but would not give me a part number. Hope this helps
Jan 22, 2011 | Sharp R-1491 Microwave Oven
Microwave will not work
Even though you don't mention the model number, you posted under Sharp model R-1491, so I'll assume that's it.
You say when trying to work the actual microwave, you get nothing?
We could use a little clarification, but FixYa only gives you one shot at posting a help request.
When you enter the cooking time and press "Start", if the timer counts down and the oven lamp comes on, but the the turntable, cooling fan, and microwave section do not run, then you have a bad secondary interlock (bottom door switch) or its mount is bad.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
Also look at this info on door switch diagnosis and replacement.
Hope this helps.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 30, 2010 | Sharp R-1491 Microwave Oven
The door to my Microwave (Sharp R-1491) will not close. The inside latches are not working. Is there a way to fix this? Or is there a microwave that you would recommend (as inexpensive as possible) that...
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
But the best place to order Sharp parts is
Encompass or you can call them at
If you need to remove it form the wall, here are two sets of installation instructions that may be close enough. here and here
If the unit needs to be replaced, you can ask Sharp if they have a "drop in" replacement. You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Jan 14, 2010 | Sharp R-1491 Microwave Oven
Need wiring diagram for sharp carousel microwave model r-1491
I found one for mind on the inside of the outside cover caseing. just need to unmount from wall and remove the six screws of the back to remove it.
Nov 13, 2009 | Sharp R-1491 Microwave Oven
Our r-1491 microwave fan won't shut off, even when
its just the door switches playing up on you,,but is it worth getting it fixed? after all a new microwave onle costs from £50 up today,,
please dont try fixing it yourself unless you realy know what you are doing in there, there is 1000's of volts hiding in there even if its been switched off for days, and them volts will kill you,
have you ever seen a stun gun working???it realy hurts you,,,,,this microwave has the stun guns big brother inside of it,,and it wont stun you,,it will kill you,, is it realy worth that for a fuw bucks?
Oct 24, 2009 | Sharp R-1491 Microwave Oven
Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Sep 28, 2009 | Sharp R-1480 Microwave Oven
Sharp r-1491
Yes call shart help line, you can find it on 411.com or googles, with you model and them the part # for the bracket and ask them were you can purchase it.
You can also try sears with your model, there or a very excelent sourse for question's on parts, if they have this model they will have all info.
Regards
Bob the builder
Feb 07, 2008 | Sharp R-1491 Microwave Oven
Sharp R-1405 / R-140 Microwave Oven Logo
74 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
