Question about Beam Q power Brush Q100
Broken handle release pedal
Handle pedal release broken, canit be repaired?
    Problem Solver:
  • 7 Answers
Definitely. Just find your local authorized BEAM dealer and they will sort it for you. Sorry, I don't know where you are so I can't find you a dealer but BEAM's website has a dealer locator.
Posted on Jul 28, 2014
How to change the release pedal on Hoover SteamVac F5914-900 SpinScrub
99 out of 100 times it's not the handle release pedal that's broken. it's the knob on the rear housing broken off. You will have to replace the rear housing. Take it to a local vac shop for repair.
May 07, 2017 | Hoover Vacuums
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Eureka Smart 4870DT Bagged Upright Vacuum
How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Mar 11, 2010 | Hoover Vacuums
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover savvy handle release pedal does not retract. There does not seem to be any mechanism to force it back, is something broken or missing, like a spring?
yes the handle release pedal is broken. i have the same problem and ordering the spare as i'm writing this email
Jul 07, 2009 | Vacuums
Bissell 3595 handle release pedal spring(?) missing
I just fixed this on my Bissell PowerForce model #6594 vacuum myself. Woo Hoo for me. :-)
I called the local vacuum repair guy and he told me he'd repair it for me if I insisted but that since my machine only cost about $80 (a lot of money for me) it would not be worth the $40-$50 repair. I should just buy a new vacuum (from him I assume).
My machine works great so I sat down on the floor and after removing 5 screws and a little tinkering I got my machine apart. I had to take the brush and belt area off and then the upright part came off the base. Make sure you unplug your unit before working on it.
Next I could see where the Handle Release Pedal (HRP) on the bottom of the unit had been cracked. It's a molded piece that has a slight curve in it that allows it to spring back into position to hold the vacuum in the upright position or to keep the vacuum from going totally flat.
How it was installed I don't think they meant for it to be easily replaced but after using a screw driver on one side and a letter opener on the skinnier side I pried the molded houseing out from around the HRP just enough to let the it release. I did need a third hand for that part.
Aug 30, 2008 | Bissell 3522 PowerForce Bagged Upright...
Whispertone powerhead handle release replacement
Use a flat blade, it just prys off, a new on will press on.
May 24, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Broken Handle Release Pedal
what is part number for broken pedal release
Oct 29, 2007 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Oct 01, 2007 | Vacuums
Beam Q power Brush Q100 Logo
135 people viewed this question
Top Beam Vacuums Experts
cazo06
Level 1 Expert
Thatvacguy.com
Jerry Kramer
Jerry Kramer
Are you a Beam Vacuum Expert? Answer questions, earn points and help others
