Question about HP Computers & Internet
HP 2509M 1-2 sec displays then fades
Monitor displays screen 1-2 seconds, then blacks out.
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX910 powers on, screen displays for 1 second then turns off
Blinking on and off is not always a capacitor issue, it is usually caused by faulty transistors at the high output transformers that light the backlights. Crappy board design ! But fixable in most cases.
Posted on Aug 10, 2008
SOURCE: IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Posted on Feb 03, 2009
  • 1684 Answers
SOURCE: ACER Al1916W goes blank in 3 seconds. It shows
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
  • 5 Answers
SOURCE: my hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Posted on Jan 13, 2010
budmrtn
  • 11361 Answers
SOURCE: my siemens LCD monitor back light turns off after 1 sec
You need to check out caps in the power supply section first, then check the backlight inverter circuits for bad fuse, transistors. It can also be bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 05, 2010
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
Uninstalation of monitor driver HP2509 stopped monitor to display.shows blank screen in vista desktop
The monitor driver only tells the video card which video resolutions are supported by the monitor. The video card is probably set to the wrong resolution. You can boot into safe mode, set the screen resolution to one the monitor supports, and you should be good to go. You don't actually "need" a monitor driver.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
HP 2509M power button lockout
that's hardware , you need to open cover and check it
Feb 19, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
Hp 2509m
Hello Laura_edw513,
The following link will open a document that contains instructions with pictures on how to disassemble the HP 2509 LCD monitor. The document is in PDF format so you should be able to save the file to your computer if you choose. This should help you with the problem you are having. I hope this is what you are looking for but if you need further assistance, please feel free to ask.
http://www.hp.com/hpinfo/globalcitizenship/environment/productdata/Countries/_MultiCountry/disassembly_monito_201041519166.pdf
Jun 13, 2012 | HP 2509M 25 Widescreen LCD Monitor -...
Hp 2509m picture stays on for a few seconds then goes to Black
I had the same issue, It actually turned out to be the backlights themselves. An easy way to check this is by shining a bright light on the screen while its on. you should be able to see the picture.
Feb 20, 2012 | HP 2509m 25 in. TV
Monitor just turns itself off after 2 sec.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 16, 2010 | HP w1907 LCD Monitor
On power on, screen comes to life for 1/10th sec, then dies. Power supply seems to be from Benq.
i just repaired a HP1955 monitor,the symptom was: when you power up the monitor,it shows on screen a desktop,but after a sec is screen going black..this repeats continously...
i just resoldered the AC cord connector on power board and also the impulse transformator...now the monitor is running good..
sry for my english,im from Slovakia
Dec 22, 2009 | HP L1955 19" LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Monitor problems
it an hardware problem i would suggest u check the display i.c of the monitor
Dec 10, 2007 | HP mx705 17" CRT Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
