Question about Navigon 2100 Portable GPS Receiver
Navigon 2100 - need to open the case to replace usb port,do not want to brake the case, don't see screw holes - help
To open the case you will need a very small flat screw driver to pop off the back of the case (be very careful as the clips holding it together are very small). You will then have four small phillip screws to remove, so that you can remove the front of the case. To remove the circuit board, there will be two very small phillip screws holding it in place once you've remove the front case.
Posted on Oct 26, 2009
  • crossbow17 Feb 07, 2011
    thanks for the great help Stantuf
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
Looking for a motorcycle mount for my navigon 2100
The following web site will be able to help you out. They have several kinds. It depends which one you want. Being a Harley you probably want the chrome. Good Luck and please rate.http://www.gpscity.com/search/q=motorcycle
Jun 14, 2010 | Navigon 2100 Portable GPS Receiver
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
Mar 23, 2010 | Navigon 2100 Max Portable GPS System
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Need users manual for navigon 2100
we purchased a used navigon 2100 it did not have a user manual with it and we would like to have one
Feb 20, 2009 | Navigon 2100 Portable GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 2100 text to speech not working
the same happened to my 2100 3.5 inch. any remediatons?
Nov 14, 2008 | Navigon 2100 Max Portable GPS System
Navigon 2100 problem
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will possibly lose any settings and addresses, but better that than a locked GPS unit.
Oct 10, 2008 | Navigon 2110 Series Satellie GPS Receiver
Navigon 2100 Portable GPS Receiver Logo
1,323 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
