Question about Audiovox Vehicle Parts & Accessories
Trojan car alarms system wiring manaul - Audiovox Vehicle Parts & Accessories
I need an operating manaul for the alarm system
Contact the Manufacturer. Maker & Model details should be on your alarm. Looks like it's a Car alarm , so have a word with your local Dealer , who will point you in the right direction.
Mar 11, 2015 | Cars & Trucks
Remove aftermarket car anti-theft system
If it is an aftermarket alarm system it is tied into your starter circuit coming off of your ignition switch. You need to remove plastic covers under steering wheel on toyota vehicles it is phillips head screws and some 10mm bolts. Find alarm system this is tricky but possible find the wire that is tapped into a thick wire leading up to steering column to the key ignition switch it should be a thicker wire sometimes red in color that wire is the starter interupt for the alarm system remove that wire (cut it) at alarm side and starter function should be restored.
IF IT IS AN AFTERMARKET SYSTEM hope this helps
Aug 02, 2014 | 1996 Toyota Avalon
Hi i need a ast-2008g alarm manaul can some one email it to me thanks in advance
E-mail me for your AST2008G Wireless Security System's Manual. thaynes@classicnet.net. Be sure and place the AST number in your title so that I will know what you want.
Tim
May 05, 2011 | Audio Players & Recorders
My alarm light blinks twice stop then twice and stop its continuous and my alarm shows a picture of the hood and trunk door up. when I press the green button to remote start my vehicle my alarm sounds. I...
The LED blinking twice and, the trunk and hood being displayed on the remote indicates trunk/hood trigger. Now, when you attempt to remote start the vehicle and nothing happens, it's definitely the hood pin switch. By the way, the remote should be displaying "inhibit" as well at this point. Check for the hood pin switch under the hood; it's probably bent downward, not allowing the pin to make contact with the hood when it's closed. If it's a bracket, bend it upwards. If it's a pin, unscrew it upwards a couple of turns so it makes contact with the hood when it's closed.
Dec 12, 2010 | Prestige Remote Start
2005 Grand Prix remote start causes alarm to sound.
remote start systems have a dis-arm alarm output wire ... this must be connected to the OEM alarm disarm wire ... your installer needs to service it.
May 08, 2009 | OEM Systems Vehicle Parts & Accessories
1998 Camary security system
See this excellent write-up on toyotanation.com below:
http://www.toyotanation.com/forum/t96974.html
It describe in details to program stock or aftermarket replacement remote. It covers all models, so just make sure you know what the FCC # on your remote when you look up this DIY.
Jan 31, 2009 | 1998 Toyota Camry
Turn alarm off for weekends???
If its anything like the RCA model I have, you have to simultaneously hit the alarm button for the alarm you want to turn off AND the off button, so both at the same time.
Oct 26, 2008 | RCA RP5420 Clock Radio
Removing trojan horse
install avast ,and quick healwith latest update one by one.
scan your pc in safe mode.
Apr 04, 2008 | Computers & Internet
Wirng up a bw10000 car alarm to a dj systems siren
If you're connecting at the alarm module - you want the red wire from the siren to go to the brown wire on the alarm(the one that's in a plug with 12 or so other wires), not the red (red wire is the constant power input to the alarm).
Feb 24, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
