Detrola record player
Does crosley make detrola turntables?
  • 104 Answers
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
Posted on Feb 11, 2009
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Posted on Apr 22, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
Crosley troubadour stops before record is done
Check to see if there is a switch setting for 7", 10", and 12" records. Sounds like a switch setting to me. Does it always pick up at the same physical location on any record? If so, that is the likely cause. Personally, if you have an extensive collection of vinyl, a Crosley is definitely NOT the best turntable to be playing them on. You'd get way better fidelity and save your records from physical groove damage by investing in a better turntable. If you want the collection to stay in good shape and retain their value, ditch the Crosley ASAP.
Dec 03, 2017 | Crosley Audio Players & Recorders
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
Can i use a crosley stylus in my detrola km837 record player
Stylus will only fit into certain cartridges. You have two options here. You can look up the cartridge number and make on your Detrola. It should be on the cartridge somewhere. Then search for the stylus. Or you can remove the Detrola cartridge and fit a new cartridge and stylus. As long as the cartridge will fit into the arm of your deck, plus it's the right type - ie: magnetic if the old cartridge was magnetic! Or ceramic - again if the old cartridge was...
Then you can use any make or model cartridge you want. As the quality of the sound can be improved - albeit paying more money for it - by having a good quality cartridge and stylus, it might be best in the long run to change the cartridge.
Jul 15, 2015 | Crosley Audio Players & Recorders
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
Lots of Turntable belts are very much universal. If they are the same size there's no reason to think it won't work on another make.
Dec 24, 2013 | Audio Players & Recorders
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
Feb 22, 2009 | Audio Players & Recorders
Jan 25, 2009 | Crosley CR248 Turntable
 Grubhead
Grubhead
