Mode Shifter Coil- How to check
How do I check the mode shifter coil on a GE washing machine? Light on indicator panel is flashig 4x indicating the mode shift circuit has failed - to check the mode shifter coil. Where is it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
It should read between o and 70ohms. if the light flashes 4 times it is out
Posted on May 19, 2009
  • ibjester1945
    ibjester1945 Oct 09, 2013
    That is great, but where is the mode shifter coil located?
Washer fills and gives two beeps, then nothing. It wont spin at all but the coil shows 60 ohm resistance.
G E washers. I usually end up replacing the motor with the model shifter the alignment shouldn't affect Anything look at the board on top of motor for a led lite 1 steady flash is normal if none check right side of harness I think it's a white wire with red stripe for a hidden fuse bypass it with a jumper wire give that a shot ge stopped using fuse
Apr 25, 2016 | Washing Machines
Ge washer will agitate or spin it will fill and drain water. have change lid switch and timer
If is is a top load model, check the motor's LED light. It will blink a series of blinks. there is a tech sheet located behind the control panel. it will tell you what the blinks mean and what to check and or replace. Probably motor or mode shifter.
Feb 18, 2015 | GE Washing Machines
When my GE WPRE6100G1WT top load washer is performing normal agitation, there's a load banging noise. I was told it may be the Mode Shifter gone bad. I've checked the counter weight, balance rods, bel
Yup, it's the mode shifter. You're going to need to change out the shaft and modes shifter assembly, along with replacing the tub seal.
You can get all of that with this kit:
Clutch
And, here is the video of how to change it:
Oct 26, 2014 | GE Profile WPRE6100G Top Load Washer
GE washer. New belt, motor worked one cycle. On second run, all works but no motor running at all. 4 flashes on pc board. Try to reset with 6 hood open in 12 secs. but not sure hood switch works. How...
The error code E4 (4 flashes of teh light) means the the shifter coil is open..the shifter coil is part of the mode shaft..to repair that the mode shaft would need to be replaced...the mode shaft is in the center of the tub its what the agitator and the inner tub connect to and would require disassambly of just about the entire washer to replace it.
As far a s testing the lid switch with a ohm meter its just a matter of determining via the wiring diagram in the control panel and find the 2 wires on it and where the connect to (sorry dont remember off hand what two wires they are) to test it when the lid is closed on those 2 wires should have continuty with ZERO omhs resistiance and when the lid is open the that circuit should be opened
GENE
Sep 01, 2011 | Washing Machines
The agitator in my washing machine is trying and notting all of the clothes up, resulting in the machine becoming unbalanced. I have taken the lid off and wached what happens and the agitator only seems to...
Is this a GE Washing Machine? This sounds like one, it sounds like the shifter coil has failed, this it's not locking to engage the agitator. So it's basically stuck in spin mode, this way, even though the tub does not turn.
Mar 12, 2011 | Washing Machines
What is mode shifter coil
It is located on top of the motor and shifts into high gear for spin.
They will go bad and need to be replaced.
May 31, 2010 | GE WBSR3140DW Top Load Washer
MODEL #WHDRR418G1WW THE RUN MOTOR HAS A RED LIGHT FLASHING 4 TIMES WHATS THIS MEAN
It means the mode shifter is open which means you need a mode shifter and a motor.
Feb 26, 2010 | GE Washing Machines
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
1,441 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
