Detrola km 837 record player
Records sound like chipmunks but the speed sounds like it adjust accordingly. could it be a pitch problem?
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
SOURCE: Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Posted on Apr 03, 2011
jmeredith
  • 417 Answers
SOURCE: my Teac sl-a100 record player
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Posted on Apr 30, 2011
stereophile
  • 36 Answers
SOURCE: AFTER adjusting the speed setting
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
Posted on May 15, 2011
  • 3 Answers
SOURCE: Just received my Jensen JTA-460
There is a speed selector directly under the needle arm.
Posted on Sep 19, 2011
The turntable is going too fast because the singing coming out sounds like the chipmunk's any trouble shooting tips??
You are likely playing a 33 rpm record while the turntable is set to 45 rpm. You need to find the speed control and adjust it to the media you are playing.
Dec 20, 2015 | Audio Players & Recorders
Plays too fast
Either the speed switch is history or there is a belt problem. Get rid of it.
Jul 27, 2017 | Sony PS-LX250H Turntable
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
May 15, 2011 | Teac SL-A100 Turntable
My Teac sl-a100 record player sounds like a chipmunk
hi,
jm
Apr 30, 2011 | Teac SL-A100 Turntable
Tracks playing at the wrong pitch and speed
This sounds like a difference in the sampling frequency.  Music recorded at 48Khz must be played back at that frequency or there will be a significant difference in speed and pitch during playback at 44.1Khz. I first noticed this when it occurred to me when recording on digital audio tape.  Ipods and minidiscs and mp3 recorders can record at high sampling frequencies like 48K.  Cds are all recorded at the standard 44.1K sampling frequency.   Check the source of your recordings and it should follow a pattern that leads to your current results.       I do not have enough information  on how your music was transferred to tell you more at this time, but I am very confident that differences in sampling frequencies of your source material are causing the pitch differences you are hearing.   Without knowing exactly the sampling frequencies of each piece of equipment you used to record these songs it will be next to impossible to give you a very specific solution, so I hope the info. I have shared helps you to figure it out.  Best regards and good luck!   Michael Mittelsdorf
Jan 12, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
How can I fix my tape player?
this unit has a variable tape speed adjustment ("pitch control"). Make sure this is set at the middle (neutral) position
Jan 11, 2009 | Tascam CC-222mkIII CD Player / Recorder
Sound speed
What are you listening to the files with? Windows media player has settings for this if you look at the expanded options.
May 31, 2008 | Acer Aspire 5100 Notebook
85 people viewed this question
 Grubhead
Grubhead
