Question about George Foreman GP160 (LP) Grill
Ned gas regulator
I need a gas regulator for a GP160 grill
  • 26 Answers
George-foreman-parts.best-price.com Large range of George Foreman parts for all models: Get deep discounts! If this helps please rate me and let me know..good luck
Posted on Jul 21, 2009
Burners won't heat adequately when I plum to bulk propoane tank supply line at my house. What is psi weber requires? Grill works fine when connected to portable tank.
For gas, it's not the psi, you need to know. It's the water column inches of gas at the grill. In which case, it should be 11 to 13 WCI.
If you didn't remove the original gas regulator on the grill. That's the problem. You bulk tank already has a regulator. However, if you LPG System is a high pressure system, then you would need a regulator, but not the one you have. Check with your LP Gas provider for the Btu output regulator that would be required.
Jul 04, 2011 | Weber Genesis Silver B Grill
Gas regulator won't let gas flow
Turn gas tank off and disconnect connection fron tank valve. Re-connect and turn gas on. Check for leaks with soapy water solution. Tighten if needed. Some regulators will detect leaks and cut off gas.
May 12, 2010 | Cal Flame 5-Burner
Replace the regulator it is bad
Mar 20, 2010 | Cal Flame 5-Burner
Grill with a full tank of gas will not get hot
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Char-Broil Patio Caddie 4654870 (LP) Grill
Heat is about low or just a little higher on high setting
May 24, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Can use gas for my liquid porpane grill
Yes you can as long as your home uses LPG. You can not use 2 regulators. If your outside line is after your home regulator you need to eliminate the regulator on your grill. LPG products operate on 11" of water column, that's about 1/2" PSI.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Frigidaire FD26LPDC (LP) Grill
Regulator broke
These are the guys you need to contact; http://www.esalton.com/control/contactus Hope this helps :)
Jun 19, 2007 | George Foreman GP160 (LP) Grill
George Foreman GP160 (LP) Grill Logo
249 people viewed this question
Top George Foreman Grilling Experts
Jaime Hernandez
Steven Clarke
Steven Clarke
Are you a George Foreman Grilling Expert? Answer questions, earn points and help others
