Question about GE GTS22WCP Top Freezer Refrigerator
Fan not blowing
No air movement in freezer on refrigerator
  • 220 Answers
SOURCE: refrigerator not blowing air at all
My pleasure, have a Happy New Year. Let me know if that is the problem, I was wondering how widespread this problem is.
Posted on Dec 31, 2008
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
SOURCE: I have a howling noise in my freezer section from
Its the noise of the air movement in the Freezer section. There are 6 slots above the light on inclined surface(2 or 3" above the light).Make sure nothing blocks it
Posted on Aug 05, 2009
aasc
  • 1606 Answers
SOURCE: freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Posted on Nov 08, 2009
My freezer is not blowing cold out. I hear the compressor running but its not getting cold
most likely bad evaporator fan motor located behind the wall in the freezer,when you open the freezer door you should hear the fan blowing in the freezer unless it's in defrost,if you don't hear it check it in 45 minutes if still no fan it's bad.
Oct 03, 2014 | Frigidaire FRS3R5EMB Side by Side...
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Freezer works but refirgerator is not cold
when you open the freezer door do you hear the fan blowing?if not you have a bad evap fan motor,if the fan is blowing put your hand on the back inside wall of the freezer,if you feel like snow on the back inside wall you have a defrost problem and have to find what part is bad with a meter,bad defrost thermostat,heater or board or timer,send model number next time,ice builds up on the coil and air can't blow into fridge from freezer,could have a bad damper,also if the freezer is on top you could have a blocked drain in the freezer,the air vents freeze up and the fan can't blow air from freezer into fridge because the air ducts are frooze up,all it does is the freezer gets cold,the evaporator fan blows cold air from freezer into fridge section,so either the fan motor is bad,the fan blade is damaged or something is blocking the air like a bad damper or air ducts are frozen up,send the model number and let me know what you find,do you hear the fan,any ice on back freezer wall or anything else you see and i'll try to help you out.
Jun 02, 2012 | Refrigerators
I can not locate the fan that blows to lower part of the refrigerator
In most older reefers, the fan in the back of the freezer does the entire job. It blows cold air through a duct that leads to the ******. If you have no cold air in the ******, but your freezer is still cold...but barely, your fan is shot.
May 02, 2012 | Kenmore 18.2 cu. ft. Top Freezer...
Refrigerator side warm bur appears freezer still
the freezer feeds cold air to the fridge side,there's an evaperator fan that just blows the cold air from the freezer to the refrigerator side and then it returns to the freezer through the air ducts.check this,when you open the freezer door do you hear the fan blowing in there?if you don't you have a bad evap fan motor,if you hear it,remove the second draw from the bottom in the freezer side and touch the back wall,if there's ice or like snow on the back wall you have a defrost problem.if this is it send me the model number and i can look up the parts in your machine and i can help you,also look to see if there's droplets and ice on the food and shelves in the freezer,somebody could have left the door open and the air ducts frooze up and the air can't blow from one side to the other,let me know what you find and i'll help you out
Jul 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
REPLACED EVAPORATOR FAN YET I CAN'T FEEL NO
There are two fans in most modern refrigerators; one that circulates the cooled air between the two compartments, another that pulls or blows air over the external coils under the cabinet. You may have bet on the wrong one.
Oct 24, 2009 | Frigidaire FRS26R4A Side by Side...
I have a howling noise in my freezer section from air movement? It sounds like wind blowing through a tunnel?
That will be either your motherboard or the condenser coils under the unit. If it just does it when the fan underneath the unit is running it's the coils.
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
NO COLD AIR BLOWING TO REFRIGERATOR
The fan in the freezer blows its air through the COILS in the freezer. If the coils are plugged with frost, there will be no breeze coming into the fresh food compartment. One other thing i have seen on Amana and Sears, is that the fan slips on the motor shaft. Make sure the fan blade is tight on the shaft.
May 04, 2009 | Amana ARS266KB Side by Side Refrigerator
Fridge transported on its side. Placed upright. Turned on too early. Freezer appears to function. Refigerator portion does not cool.
If the freezer works the cooling system is ok. Check for the freezer fan it blows air to the refrigerator side. Also check the air vent. It should be in the top of the refrigerator. If the fan is blowing you should be able to feel the air blowing out. I would see if the fan blade came off in transport first.
Apr 24, 2008 | Refrigerators
The refrigerators accumulate ice
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
Nov 29, 2007 | Liebherr Premium CTP 3153 Top Freezer...
GE GTS22WCP Top Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
