Blue spot on screen
I have a 52'' Mitsubishi Rear projection- there is a blue bar about 3'' tall & 18'' long at bottom left of the screen - what can it be ?
  • 6,784 Answers
Hi. this is called convergence failure. the convergence board is a circuit board that regulates the RGB(RED BLUE GREEN) streams that make up the color picture. If the convergence board chips are malfunctioning, you will see a distorted view of these RGB streams. This is what you are experiencing at this time.
Simply replacing the convergence board or chips will fix this issue.
Please rate and have a great day:)
Posted on May 17, 2009
Picture blotchy blue
DO IT HAVE WITHE SPOTS ON THE SCREEN AS WELL IF SO THE CHIP IS BAD DMD BROAD
Sep 27, 2013 | Mitsubishi WD-52525 52" Rear Projection...
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Have a blue spot on the screen. started just
Hi,that's an issue with the light engine.Basically there's 3 chips blue,green and red they create the image on the tv ,when they start to fail you'll get those spots all over, mostly in the corners.God bless you!
Oct 05, 2009 | Mitsubishi WD52527 52" Projection HDTV
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Mar 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
