Trying to connect a soundbar to a blaupunkt television cant find aux out ports on tv
Hi im having problems connecting a goodmans soundbar to a blaupunkt tv i dont know where cables go
  • 395 Answers
SOURCE: connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
Posted on May 21, 2008
so_cal_steve
  • 25 Answers
SOURCE: WHERE IS THE AUX IN PORT
It's probably located in the back. buy an extension for it from fry's and run the extension somewhere convenient to plug your ipod in.
Posted on Feb 01, 2010
bdouglas
  • 290 Answers
SOURCE: connecting to ports?
Generally the input/output jacks on computers are color coded and the green is for speak output. If you still don't get sound, verify you have working sound card drives installed in your OS and that the volume isn't muted.
Posted on Jun 12, 2010
  • 7 Answers
SOURCE: When trying to connect a phillips soundbar/dvd
If this equipment does cause harmful interference to radio or video reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the W4207 HD Monitor and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the Westinghouse Service Center or an experienced technician for assistance.
DVI CONNECTION: Connect a Digital DVI cable from your computer to the W4207 HD Monitor DVI port. Using a 3.5mm mini cable to RCA Red/White (Left/Right) audio converter cable, connect the 3.5mm cable plug into the computer
Posted on Dec 13, 2010
  • 132 Answers
SOURCE: I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Posted on Jan 12, 2012
Testimonial: "Thank you very much."
I have just bought a samsung soundbar hw h355 and I'm trying to connect it up to my toshiba tv, via the aux cable but I get no sound from it via the tv link. I works when I link my phone up via Bluetooth....
Please get a optical cable and run it from TV to soundbar for best sound. If you are using aux input on sound bar that will work but it is analog sound. TV needs to have mini audio out or red/white output on it maybe labeled audio out
Feb 10, 2015 | Samsung Audio Players & Recorders
How do I connect a Goodmans sound bar to my Toshiba Regza tv as the manual says connect via Aux
hook the soundbar to your axillary output or audio output or speaker output
Jan 08, 2015 | Toshiba Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
I am trying to connect a LG sound bar to my Blaupunkt 50" TV. I havent got a digital optical connection on the TV. How can I connect the soundbar?
There should be audio output with your TV. Connect it with the Sound bar; using an AV cable. The cable might have three cores to connect, but you need to connect its Red and White pins. Leave the Yellow pin free; as it is meant to connect to Video. Electro help
The connection cable will look like this.
Dec 12, 2014 | Televison & Video
How do i connect a soundbar to my tv
Each TV is different. With make and model I should be able to help.
Sep 26, 2014 | Televison & Video
Why doesnt my goodmans soundbar work? It is connected to aux on tv and soundbar only makes buzzing sound
The AUX sockets on the TV are for sending a signal in to the TV. This is what's known as an input.
Signals don't come out of any socket that is labeled in or input. If you want signals to come out of a device, then the correct socket to look for is labeled out or output
The cheapest way of connecting your flats screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
Sep 08, 2014 | Televison & Video
Just purchased a Goodman 50 w sound bar connected to AUX on tv and sound bar clicked AUX on remote white light shows no sound just a loud buzz
To the best of my understanding an Aux port is usually an input port. So you might be sticking the sound bar terminals into the wrong connector in TV. The audio signal from the TV is meant to go into the Aux In port of the sound bar. Usually this will mean a pair of RCA cables (white and red) from TV out to Aux In. If you have done the right things then maybe check if soundbar is not in mute. Try some other source as well. Like connecting an iPhone or ipod stereo out to the Line In port in soundbar and selecting LineIn mode.
see page 7 in the soundbar manual. It is hard to know what TV connection you are using. Is it selected on the TV settings? http://www.goodmans.co.uk/support/downloads/user-guides/GDSB02BT20-ib.pdf
Trying to connect samsung soundbar to Technika tv. Plugged aux cable (red and white) into tv then other end (black) into the soundbar. Still no sound.... Help ?
Hi probably a silly comment - have you connected to the AV in or Out sockets on the TV? Worth checking? also do you need to select an audio profile on your TV in order to divert from the internal speakers. Worth looking at your sound preferences on your TV
Jun 24, 2014 | Audio Players & Recorders
18 people viewed this question
 Grubhead
Grubhead
