Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Very hard to start
Once started , stalls @ idle
  • 10,865 Answers
Your carbeurator is gummed up, a very common problem after a winter of sitting idle. Go to any auto parts store and buy a bottle of carbeurator cleaner which is added to your gasoline, usually one ounce per gallon. Also buy an aerosol can of carbeurator cleaner which you spray directly into the air intake by temporarily removing the air filter.
If you havn't replaced the spark plug and the air filter in a while do those things also, and use freshly purchased gas, not gas that has been sitting around for months.
Posted on May 17, 2009
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
96 chevy s10 v6 stalls after i start it up
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 18, 2012 | Cars & Trucks
Hard Starting, Rough Idle & Stalls 1986 Nissan Maxima Problems & Solution
Sounds like a big vacume or intake leak. 1st check your intake tube make sure it has no splits also look under the tube with a mirror. Check clamps. Another possible is fuel flow & pressure. There is a couple of places to start.
Jun 20, 2012 | 1986 Nissan Maxima
Eratic idle,stalling,hard to start
do tune up and clean throttle body see if that helps
Feb 21, 2010 | 1993 Saturn SL2
Rough idle. stalling,hard starting
It is probably your IAC valve.
Sep 17, 2009 | 1985 Honda Civic
1999 dodge caravan stalls when pyt into drive
try a new set of plugs, wires, and fuel filter. full loaded tune-up. air filter too.
May also be mass-airflow sensor if equipped. does it display a Check engine light?
Feb 23, 2009 | 1999 Dodge Caravan
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
198 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
