Question about Toshiba 36AF43 36" TV
Slightly slanted screen/picture
My television's picture has become slightly slanted.  The top left corner of a picture drops down about 1/2" to 3/4" and shakes.  From here, it tapers off towards the upper right corner of the screen, but still shakes somewhat all along the top of the screen.  On the bottom of the picture, there is a much smaller line, beginning on the right side of the screen that also is very shaky and slanted.  In turn, if a movie or show is a "widescreen", it is quite obvious that the picture is slanted down and to the left; following with the slant of the screen.  Is there any troubleshooting tips you could offer for this problem?  Your help is greatly appreciated!!
    An expert who has answered 500 questions.
  • 556 Answers
Re: Slightly slanted screen/picture
Your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Posted on Oct 17, 2007
0 characters
3 Points
Turn the TV on and a minute after the picture comes on the picture scrunches up to the top of the screen and colors are distorted. It the goes black. I turn the TV off and on and the picture is sometimes...
try to tap your tv slightly at the side if it go back to normal operation you have a weak solder commonly in the main board try to resolder parts that is slightly hung.
Oct 15, 2010 | Sony Standard (CRT) Televisions
Tilted picture
You must be placing the TV near something Magnetic, Speakers, etc. This would account for the green in the corners. The tilted picture is most likely the yoke in the set has moved during rough handling. The first issue can be fixed with a degausssing coil, the second requires a technician to manually realign the yoke assebly and perform a convergence on the set.
Apr 20, 2009 | RCA TruFlat 27F520T 27" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Tv picture
The adjustment is done by opening the TV back cover, the part that looks like a cone(YOKE) that is mounted at the back of the picture tube needs to be slightly rotate it. To do this you will need to loose the screw that is holding that part and rotate it left or right.
Before doing this, unplug the TV from the main AC power.
Hope this helps.
Apr 25, 2008 | Emerson EWF2704 TV
Slanting Picture
The yoke has probably come loose and tilted.. From the rear of the set looking on the back of the crt you'll find a copper wire wound magnet called the yoke. It terminates on the neck of the yoke with a clamp. With the set off slightly loosen the clamp and turn the yoke assembly in the opposite direction - key word here is slightly - and apply power to check the alignment.
Keep doing this until you achieve the alignment you want. And always remember to unplug the set between attempts.
Nov 05, 2007 | Sharp 32SC26B 32" TV
Part disclored picture
as it has fallen on the floor
due to that its deflection coil position might  have  changed a little.
due to that its left corner has gone down.
deflection coil has convergence magnet on it so due to that there is change in color also.
please call tech to re position of deflection coil every thing will be fine as it was.
as per buying another it is up to you.
hope this will help.
Oct 10, 2007 | Sylvania 6842PE TV
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Nov 05, 2006 | Philips Magnavox 20MT133S 20" TV
Corner of picture missing
There is nothing you can do ,the units has a service problem and need to be diagnose by a qualified technician,something went bad and it needs to be replaced.Be safe and call for an estimate.
Sep 17, 2006 | Emerson EWF2704 TV
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Toshiba 36AF43 36" TV Logo
275 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
