Question about Bosch B22CS50SNS Side by Side Refrigerator
Locked control and display panel
All buttons on display panel are locked. Shows to be in Sabbath mode. Manual says to simultaneously press options and + buttons for 5 seconds. I have tried turning off and unplugging for 5 minutes.
3 Suggested Answers
SOURCE: machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
Posted on May 15, 2009
  • 500 Answers
SOURCE: Bosch exxcell 7 washing machine
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Posted on Jul 08, 2011
What does SABB mean on ge french door refrigerator
Sabbath mode someone pushed some buttons and caused this or touch panel shorting. Need to read owners manual to clear
Jun 20, 2015 | GE Refrigerators
Inside lights of KitchenAid KSF26C4XYY not illuminate
I bet your fridge was put into Sabbath Mode.
Sabbath Mode is designed for those whose religious observances
require turning off the lights and dispensers.
In Sabbath Mode, the temperature set points remain unchanged,
but the interior and dispenser lights turn off, all sounds and alarms
are disabled, the dispenser display screen backlight turns off, and
the dispenser levers are disabled
To turn on Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds. When the feature
turns on, "Sabbath Mode" will appear on the dispenser
display.
To turn off Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds again.
Apr 15, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Frigidaire Gallery side by side error codes
SB is in "Sabbath Mode".
The Sabbath Mode is a feature that disables portions
of the refrigerator and its controls .
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "down" and refrigerator "up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode.
Jul 04, 2013 | Refrigerators
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Bosch B22CS80SNS sxs with no lights
You can get the manual here. on page 16 it tells you how to take off savagemode.
Sabbatical mode settings:
– Accoustic signal is switched off.
– Super cool or Super freezing
functions are ended (if activated).
– The interior illumination is
switched off.
– The light on the display panel is
reduced to basic lighting.
– Buttons are locked (except
“options” and “+” buttons).
Switching on and off:
̨ Simultaneously press “options”
and “+” buttons for 5 seconds
When switched on, [Sabbath] is
indicated on the display panel.
Good Luck
Nov 02, 2009 | Bosch Refrigerators
Range shows 'SA 66" in display
After calling customer service with no satisfaction, I did a Google search for SA66 which turned out to be really SAbb code. I found out that this is a special "Jewish Mode" that I somehow turned on while pushing the touch pad disabling it. To end the "Sabbath Mode", Press CANCEL/OFF FOR ONE SECOND, then press and hold Number Pad 6 for five seconds. It worked!
(You can also press and hold the Number Pad 6 for five seconds first, followed by CANCEL/OFF.)
Mar 07, 2008 | KitchenAid KESC307 Electric Kitchen Range
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Bosch B22CS50SNS Side by Side Refrigerator Logo
56 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
