Question about Aiptek Media Tablet 14000U
The pen won't work
I want to move my pen on screen, but it only works when I drag it on the tablet. What should I do?
Genius G-Pen 560 Tablet Driver won't Install on Windows 7
If you have Windows 7 Professional or Ultimate you can install XP mode and Windows Virtual PC on top of Windows 7 and run XP mode.Install the drivers on XP mode and you should be able to use your tablet.
Virtual PC and XP mode are available free of charge on the Microsoft web site. The site requires authentification to verify that your copy of Windows is genuine.
Apr 03, 2012 | Genius G-Pen 560, USB 4.5 x 6 tablet with...
My Wacom pen doesn't work. The blue light on the tablet turns green when I touch the pen to it, but the cursor doesn't move on the screen. I thought that the tip needed to be replaced, but after changing...
Does the mouse work (on the tablet)? What happens when the side buttons are pressed do they work? Try un-installing the Wacom driver (Pen Tablet Utility) and Install the latest version from www.wacom.com and see if that helps.
Mar 05, 2011 | Wacom Intuos3 Graphic Tablet
Tablet Pen moves very slowly across the screen. It used to work fine, but the last few times I've tried, the mouse ends up moving faster. I used to be able to move the pen across the tablet and the mouse...
This may be a processor issue, as mine does this too.
As for others, most issues surrounding the stylus are battery related.
I will help anybody with a broken, or inoperative stylus/pen get their pen operating again. I have started a business around this issue because so many people's pens are malfunctioning (including mine originally which drove me to do this). This was fueled by Gateway's lack of caring around the issue, and their attempts to charge ridiculous fees for customer service. I charge $20 to switch out the battery to get your stylus working again, plus shipping and handling both ways, about $25 total.
Email me at: kevin teman AT hotmail DOT com
Or,
See my website at:
[url=http://www.kevinteman.com/stylusrepair]Stylus Repair and Battery Replacement[/url]
Thank you, Kevin Teman kevinteman.com/stylusrepair
Feb 25, 2010 | Wacom (EP130EPE) Digital Pen
Tablet pc pen isnt working its moves around when i put hte pen to the screen but its like theres no pressure it wont click
A common problem with touch screens on Palm Pilots is contamination getting under the edge causing pressure that fools the screen to thinking there is pressure under the lip of the bezel. There MAY be a similar thing with your tablet PC.
Jan 09, 2010 | Gateway M275 Tablet PC
Hanvon Tablet works incorect
as with most HID hardware (human interface device) there are settings. Most of the time, the settings allow you to customize what function does what in an application. You may need to read the documentation for your tablet PC to determine how to set an application profile for photoshop CS3 / 4.
This is what i had to do to get my wacom tablet to function correctly in photoshop..
Or, if your stylus has a set of buttons on it, try pressing one when dragging to see if that's the issue. if so, i'm sure it can be changed to fit your needs.
May 11, 2009 | Computers & Internet
My Pen Doesn't Work
ya, i had teh same problem ... i had recenlty downloaded "pen attention" its a software that some guy made to make the pen curser look bigger in one note ... i uninstalled this program and now the problem is gone!!! so just make sure that you delete any programs that you have downloaded tht might be interfeering the the tablet's performance (especilaly programs or addons that my have been developed by non-wacom personelle for the tablet)
Jan 09, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom bamboo problems in photoshop CS2
Yeahhh! Installing the new driver completely fixed my problem! Thanks guest!
May 09, 2008 | Computers & Internet
Graphire4 Pen Problem
throw it in the trash and get a proper tablet
Oct 15, 2007 | Wacom Graphire4 Digital Pen
Screen rotates, pen doesn't
Is it maybe possible it is a hardware prob? maybe the directional sensor in the tablet was displadced.
BTW i have the same tablet and need an harddrive replacement/upgrade, how did you manage to do that? what kind of drive and where to buy? Viewsonic seems not so eager to help me out with that.
Best,
Fredrik
Apr 25, 2007 | ViewSonic Tablet PC V1100
Aiptek Media Tablet 14000U Logo
49 people viewed this question
Top Aiptek Computers & Internet Experts
David
David
Willem.
Willem.
Gareth Cockram
Gareth Cockram
Are you an Aiptek Computer and Internet Expert? Answer questions, earn points and help others
