Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Whirlpool range GR470LXMB temperature stuck on 350
Whirlpool range temperature does not change anymore. I can only bake on 350 degrees.
2 Suggested Answers
  • 18 Answers
SOURCE: Whirlpool oven temperature does not change
sound like your thermostat is faulty
Posted on May 17, 2009
Whirlpool gold oven
One must preheat the oven to the desired baking temperature. If the oven is turned on and the food immediately put in to bake, it will take longer to bake the first batch than the second and subsequent batches, because the oven need a few minutes to heat up.
In other words, the oven isn't at 350 degrees the instant you turn it on. It takes about 15 minutes for the oven to reach 350 degrees. I hope this helps.
Jan 20, 2014 | Kitchen Ranges
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Nov 27, 2008 | Whirlpool RF364 Electric Kitchen Range
Oven stuck on pre-set temperatures!
Replace Electronic Range Control (ERC)and touch pad sorry .
Jan 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
106 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
